will a 4.0l engine work in my 3.4l runner?
If they'll sell the ecu and tranny do it. I think one big headache MIGHT be the ABS getting to jive between the new ecu and existing hardware, also the speed sensor, the tachometer and speedo might be a SOB but if you can get it all reasonably priced, it would be a good step in power.
There are all kinds of issues with transfer case hookup & engine height, not to mention it's a drive-by-wire throttle, plus a host of other issues. Like One_96TR4 said, it was done & the write-up is on here somewhere, but it cost 'em a ton and took a long time & good mechanic. Last I read he was having issues with some sort of binding with the front diff...
Thanks all for the quick responses. After a few hours of research I've decided to continue searching for a cheap 3.4l as I need my vehicle operational soon. I'll post some pics of the existing engine after we pull it and find out what happened without any warning whatsoever, that is if anyone is intersted...
true that, I have and Acura Integra too and that car can have like 5 different engines easily installed into it...different honda engines that is...same with civics, they can have my motor bolted directly into them and running like a raped ape in like 3 hours...
A diesel would be sweeeet....25mpg is nice...
u can put a new honda civic 4 cylinder engine into an old del sol pretty easy, huh? a buddy at work did it, and man is that thing fast. tho he CLAIMS to have spent 20k on the swap alone... id say he spent 800 on the motor (brand new from honda of poway) and the rest on the suspension. ...if he even spent that much.
voiddweller
19
May 2, 2016 09:10 PM
FS[PacNorWest]: T100 auto trans/tcase - Bay area, CA
94whiterunner
Sep 22, 2015 07:25 PM
TheManOutside
Jun 18, 2015 03:32 PM
DuckFan
11
Jun 18, 2002 11:56 PM
