Suspension woes
You should extend your bumpstops.....your springs will thank you. You could also move your axle forward a tad with these: http://allprooffroad.com/index.php?o...ask=view&id=51 because, if you're like me you don't want to hack up your clean fenders!--------Hans
I think my springs are same length as stock. I still have them somewhere so I will check.
What is the proper angle for the rear shackle relative to the spring at level unloaded? I have been thinking longer aftermarket shackles and brackets as well.
and front unloaded-level ?
Short of moving the shackle hanger (cut and re-weld) you probably just need a longer spring shackle to handle the length change of the springs:
- http://www.4crawler.com/4x4/CheapTri...l#Applications
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ3
thanks everyone for the help!
You can follow the steps on my first link to figure out exactly how long a shackle you need. Or if you have the old springs, measure their arc length (i.e. along the arc of the springs, eye-eye) and that of the new springs and then size the shackle 1" longer for each 1" extra arc length:
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ2
Thanks 4crawler
The simpler the better for me, always!
Just checked arc length is 1" longer than stock on 3" lift rough country rears and 1/2" longer than stock on 3" lift Downey fronts.
Stock shackles are 3.5" hole to hole
I think I will keep the stock front shackles and order a 1" longer rear set.
Driveline angle looks good, I have shims from the rough country kit installed.
Thanks again!
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
