Suspension woes
Old Jul 26, 2008 | 07:35 PM
texcat101's Avatar
Suspension woes
with the suspension loaded up on the left rear I felt it rub so I stopped and took this picture. stock shackles w/3" leafs
What are my options?
Old Jul 27, 2008 | 06:26 AM
texcat101's Avatar
bump, I could use a little more lift in rear. these shackles laying all the way down when loaded up was a surprise. I would appreciate advise on this problem. Thanks for your help
Old Jul 27, 2008 | 06:58 AM
texcat101's Avatar
Bump, Just bumped this morning when I woke up then had to do it again to get it back on the new posts list. Corey?
Old Jul 27, 2008 | 08:00 AM
jason191918's Avatar
I have no advice but I will bump it for you.
Old Jul 27, 2008 | 08:57 AM
grovedogg's Avatar
larger bumpstops, unless you wanna cut your fenders
Old Jul 27, 2008 | 09:06 AM
Oatmeal's Avatar
You should extend your bumpstops.....your springs will thank you. You could also move your axle forward a tad with these: http://allprooffroad.com/index.php?o...ask=view&id=51 because, if you're like me you don't want to hack up your clean fenders!--------Hans
Old Jul 27, 2008 | 09:48 AM
85toy's Avatar
are your lift springs longer than stock? if so it looks like you need to move you shackle hanger back more.
Old Jul 27, 2008 | 11:57 AM
texcat101's Avatar
Good advise x2 I will do both asap
I think my springs are same length as stock. I still have them somewhere so I will check.
What is the proper angle for the rear shackle relative to the spring at level unloaded? I have been thinking longer aftermarket shackles and brackets as well.
Old Jul 27, 2008 | 12:12 PM
texcat101's Avatar
Pics of proper angle level unloaded would help greatly.
Old Jul 27, 2008 | 03:24 PM
jodaddy's Avatar
I took a picture but I can't seem to shrink it enough to post it. The shackle is at about a 40 degree angle to the frame unloaded on my stock springs. I hope that helps.
Old Jul 27, 2008 | 05:37 PM
texcat101's Avatar
Thanks jodaddy that does help, stock setup should be right. If I can replicate that on my setup. this is what mine looks like unloaded. Does this look right?
and front unloaded-level ?
Old Jul 27, 2008 | 06:26 PM
4Crawler's Avatar
Short of moving the shackle hanger (cut and re-weld) you probably just need a longer spring shackle to handle the length change of the springs:
- http://www.4crawler.com/4x4/CheapTri...l#Applications
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ3
Old Jul 27, 2008 | 06:57 PM
muddpigg's Avatar
If you use longer shackles check your driveline angles. If you are wondering what that is research the links listed above before you ask.
Old Jul 27, 2008 | 07:17 PM
texcat101's Avatar
looks like longer shackles are the answer I will do the math tomorrow to find out how much longer. But from the 3" lift springs it sounds like 2" or so, I would like to be able to order the shims at the same time as I am running out of time before my trip. I think I can figure that pretty close by drooping the springs to represent the longer shackles then checking the driveline angle.
thanks everyone for the help!
Old Jul 27, 2008 | 07:21 PM
4Crawler's Avatar
You can follow the steps on my first link to figure out exactly how long a shackle you need. Or if you have the old springs, measure their arc length (i.e. along the arc of the springs, eye-eye) and that of the new springs and then size the shackle 1" longer for each 1" extra arc length:
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ2
Old Jul 28, 2008 | 03:07 PM
texcat101's Avatar
Thanks 4crawler
The simpler the better for me, always!
Just checked arc length is 1" longer than stock on 3" lift rough country rears and 1/2" longer than stock on 3" lift Downey fronts.
Stock shackles are 3.5" hole to hole
I think I will keep the stock front shackles and order a 1" longer rear set.
Driveline angle looks good, I have shims from the rough country kit installed.
Thanks again!
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
ktm192k
Oct 1, 2015 08:47 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
