OEM back springs from 3rd gen 4Runner in a 2nd?
well it seems that my rear sag in my 94 4Runner is getting worse and worse. at least its seems. i don't know if its just me, but anyways its pretty bad. i was just wondering if anybody has every tried taking OEM springs from a 3rd gen and putting it a 2nd gen. David (madchemist) has some 3rd gens left over from his lift.
also i was wondering if the 3rd gen springs are stiffer because they don't seem to have a problem with the rear sag.
any info is greatly appriciated. thanks!!
from what i understand the reason 2nd gen sag happens is the spring rate was the same as the lighter rear end pickups, and this problem was solved in the 3rd generation. as far as the springs go i have no idea. i got rid of my old springs from the downey swap, but if someone has thiers laying around get some dimensions to see if theres a major difference.
or maybe someone will know the answer straight out. . .
Re: OEM back springs from 3rd gen 4Runner in a 2nd?
EDIT: They only have about 5k miles on them
4runner and truck rears are different
The pick-ups actually have a leaf spring set-up vs. the rear coil spring set up on the runner. So, the sagging spring syndrome is caused by a poor spring design on the 4runner alone, which was allegedly updated to curb sag over time.
You guys with 2nd gen 4Runners need to talk to Flygtenstein (Adrian) about rear coils. He found that certain years of Landcruisers (FJ-80s, before '96 or 97??? I can't remember) have taller coils that will work for you. Send him a PM and I'm sure he can tell you all of the details.
3rd gen coils are of a slightly different diameter and have different size perches, I think...
Co-Founder/Administrator
Kevy, as Jayson said, contact Adrian.
But why not go with a proven coil that works?
Many of us 2nd genners go for the Downey HD coils.
http://www.toyotaoffroad.net/tando/forumtemp/downey.jpg
It's a proven design, and made to cure your saggin' rear.
Mine have been on since the spring of '99, and not sagged a bit, even with over 300 lb of cargo in the rear.
Average price is $160 to $170.
Three places to get them.
1. Downey (search on forum for phone # or look on my personal website in the links area)
2. Mike @ Xtreme Off-road on the forum here
3. www.central4wd.com takes phone orders and will ship them to you.
I had a brain fart and think that Adrian got the used LC coils from Slee Offroad , so you may just give him a call or email and get the specs. I think they were pretty cheap, somewhere less than $100...
infinityisfive
Jun 16, 2015 06:51 PM
peterbilt
Jun 11, 2002 10:28 AM
