what tranny do i have?
Go to your truck, open the door and on the sill, by the door, there is the manufacturer's info. At the bottom right corner, it will say W56 or G58. Thats your transmission. If you have ADD, then from what I've heard, its probably that you have a G58.
84-88 Truck and 84-89 4Runner EFI used a W56 transmission. Easiest way to identify an 84-88 W56 is the top shift plate. It will have 6 bolts holding it down, and 4 bolts holding the actual shifter to the shift plate.
You need to look under the hood to get the correct info plate.
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
