Old Feb 10, 2016, 09:25 AM
How-Tos on this Topic
Last edit by: IB Advertising
    Print Wikipost
    2nd gen 4runners lift guide
    Old Sep 24, 2008 | 05:47 PM
    SR5's Avatar
    SR5
    I did some research on what type of lift kit i wanted for my truck, and i rang into a lot of lifts, so i thought id post them, as a helpful guide for beginners
    First off let me explain that you do not need a lift kit to fit 33x10.50 or 33x12.50. the 10.50 will fit with no rub at all, while the 12.50 will fit with some rub, backspacing will help take care of that rub
    example:
    Also you can do a body lift for Farly cheep
    Example with 2" body lift
    Old Man Emu lift kit options
    Option (1)
    2"-3" Lift (approx.)
    Sdori 1.5" Ball Joint Spacers (1pair)
    Sdori 2" Coil Spacers (pair)
    OME N98 Front Shocks (each)
    OME N71E Rear Shocks (each) FJ80 Shock
    OME 901HD Coil Springs (each)
    OME SD33 Steering Stabilizer
    Total $638.65
    Option (2)
    1.5"-2" Lift (approx.)
    OME N72F Rear Shocks (each)
    Total $501.24
    Option (3)
    OME N72FRear Shocks (each)
    Total $454.72
    Example of 2" OME lift
    2" 4Crawler lift
    1.5 BJ spacers and 2" coil spacers $189.00
    1.5" BJ spacers and 80 Series Land cruiser coils
    80 series land cruiser (1990-2008)
    *lift 3" * Also If you get them of a truck, they come one short sided one long, just the way they are, so try to get a pair of short sided, or longer sided, only about 1/4" difference
    Example with of 1.5" BJ spacers and 80 Series Land cruiser coils
    80 series land cruiser on 33x12.50
    4-5" Rough Country lift $609
    *Now this is meant for an 86-96 4wd IFS Pickup, however all you need to do is replace those blocks with 80 Series Land cruiser coils.*
    4" Trail Master lift $1,642
    *Notice it would have coil springs for the rear, not blocks*
    4" Procomp lift $1,373
    Example of 4" and 33x12.50
    If their is any i forgot, or you think i should edit something let me know.
    pics and specs of more yota!! https://www.yotatech.com/forums/f116...r-yota-155366/
    Old Sep 24, 2008 | 05:59 PM
    Elvota's Avatar
    Nice compilation so far.
    This might make for a good sticky if others add their personal experience and researched pics or specs as well.
    Old Sep 24, 2008 | 07:19 PM
    SR5's Avatar
    SR5
    thats kinda what i had in mind
    so cmon guys post them
    Old Sep 24, 2008 | 07:30 PM
    Mic09dcsm's Avatar
    So how does option 1 get you that much lift, in the front especially, 1.5-2" t-bar crank or what? The rear coils and spacers make sense though.
    Old Sep 24, 2008 | 07:36 PM
    Alex 400's Avatar
    If you plan on cranking the torsion bars, i would suggest getting the old man emu torsion bars as a replacement..
    Old Sep 24, 2008 | 07:49 PM
    olharleyman's Avatar
    Originally Posted by SR5
    that's kinda what i had in mind
    Pro Comp Stage II with 35 x 12.5's and slight to fender pinchweld's no cranking on torsion bars.
    Also I got the kit for $950 delivered from 4wheelparts not trying to push there site but I did get the step up for cheaper through them all I did was tell them I seen it on sale on another web site but that they where a drop ship place and they matched the price. Just a little info to help save someone a few bucks.
    Almost forgot rear coils are replaced with custom built heavy duty coils
    Old Sep 24, 2008 | 07:52 PM
    turboboost's Avatar
    Holy, this is a great guide! I'm very impressed.
    Old Sep 24, 2008 | 08:19 PM
    SR5's Avatar
    SR5
    i was curious about that to, but that is what i assumed
    here is were i got it from
    https://www.yotatech.com/forums/f37/...s4u-com-54794/
    Old Sep 24, 2008 | 08:43 PM
    Mic09dcsm's Avatar
    That doesn't make any sense, unless they're just accounting for the rear where height is gained because of spring sag.
    Old Sep 24, 2008 | 08:47 PM
    Matt16's Avatar
    Great post. This should be pinned at the top, or archived in the offroad enhancements.
    One note though, my truck is stock height in the front end- 14" from fender to wheel lip. I relaxed the torsion bars to get better flex.
    Old Sep 24, 2008 | 08:51 PM
    hurley842002's Avatar
    Good work man. Very valuable info for those new to wheeling. Hopefully they will utilize it.
    Old Sep 24, 2008 | 09:05 PM
    fillsrunner4's Avatar
    WOW weres the real lift kits???
    SAS kits!
    Marlin
    Trail gear
    Allpro
    Rear kits
    Offroad solutions SAS coils
    Just to add a few!
    Old Sep 25, 2008 | 08:54 PM
    SR5's Avatar
    SR5
    good keep them coming
    Old Sep 25, 2008 | 11:33 PM
    Jay351's Avatar
    Just a few things..
    Your first picture, those tires rubbed pretty bad on that truck. Should note that to really cut down on trimming, you wheel needs to be stock backspaced (or very close).
    Option 1, 3-4" of lift? No. 1.5-2" tops. There is no way to get 4" out of just bj spacers without totaly throwing your front end out of whack.
    Other then that, pretty good
    p.s Love that the bracket lifted 4runner has those stupid chrome rims
    Old Sep 26, 2008 | 10:18 AM
    woodendude's Avatar
    What year of 80's series Landruiser coils, or does it matter? Do you have a part number.
    Old Sep 27, 2008 | 11:13 AM
    SR5's Avatar
    SR5
    OME 895
    and as long as its 80 series it don't matter
    Old Sep 27, 2008 | 11:14 AM
    SR5's Avatar
    SR5
    Originally Posted by Jay351
    Just a few things..
    i know i didnt like that option ill change
    but here i got it from strap 22
    Old Sep 27, 2008 | 11:15 AM
    SR5's Avatar
    SR5
    Just a few things..
    ok i changed option 1 to 2"-3" and added that you need backspacing on a 33x12.50 and no lift
    Old Sep 28, 2008 | 10:31 AM
    Matt16's Avatar
    MY EYES....ARRGGGHHHH!
    Old Sep 28, 2008 | 11:14 AM
    crawyota's Avatar
    From: CHESTER COUNTY , PA ; by way of KOBLENZ , GERMANY
    here is what I did with my second gen. I got a set of FJ80 rear coils $85.00 , shocks $120 / set , Tires (MAXXIS BIGHORN MT'S 255/85/16) $600.00/ SET , labor / case of beer, and crank the TORSION BARS up front.
    here is the end result
