Uploading WAY faster than downloading
Old Jun 5, 2005 | 12:02 PM
oly884's Avatar
Guest
This isn't just with file sharing programs, this is overall. An example, I can up load at about 200-300 kbs, but only download at 30 maybe 35 kbs. This has been this way for a long time and I've tried a ton of different sites, etc. And it seems to be constant with that. Any ideas why this is, and is there anything I can do about it?
Old Jun 5, 2005 | 12:08 PM
tulsa_97SR5's Avatar
Have you tried the tests on DSL reports? They have a good speed test, but there's another one that checks some other paramaters & suggests changes. They also have a neat little program, drtcp i think that helps with some of the changes.
Old Jun 5, 2005 | 12:14 PM
oly884's Avatar
Guest
I'll give it a shot, thanks!
Old Jun 5, 2005 | 12:37 PM
midiwall's Avatar
Like Brian mentioned, start with the speed tests here at BroadbandReports.com to see some real numbers:
http://www.broadbandreports.com/stest
Then, head to this page (same site) for the tweak test to get some ideas on things you can adjust on your side.
http://www.broadbandreports.com/tweaks
One thing to try before the speed test (or after to see if it helped) is to unplug/replug your modem and/or router. My DSL modem gets a bit whacked once every 2-3 weeks and my download speeds drop by a factor of 5. Rebooting (unplug/replug) fixes it up.
Old Jun 5, 2005 | 02:26 PM
oly884's Avatar
Guest
nothing is changing, my RWIN value doesn't change and i've tried all the tweaks.
2005-06-05 18:25:18 EST: 228 / 3288
Your download speed : 233713 bps, or 228 kbps.
A 28.5 KB/sec transfer rate.
Your upload speed is much faster than down.. have you tweaked?
Your upload speed : 3367003 bps, or 3288 kbps.
upload is really WAYYYY faster
Old Jun 5, 2005 | 02:42 PM
Are you on cable or DSL?Only user on your connection? Did the tweak test recommend any changes? That IS really strange, and my first thought is someone else is using your downstream bw. What is your RWIN btw?
Old Jun 5, 2005 | 02:58 PM
oly884's Avatar
Guest
I managed to change my rwin to 13140.
I'm on DSL, it's provided by my apartment complex so I assume that that has something to do with it.
Old Jun 5, 2005 | 03:04 PM
4-RUNNIN' FREAK's Avatar
My U/L speed is more than others, but I'd rather have a higer D/L speed.
Originally Posted by Corey
2005-03-24 08:07:27 EST: 3747 / 327
Your download speed : 3837398 bps, or 3747 kbps.
A 468.4 KB/sec transfer rate (what you see on a download when saving a file)
Your upload speed : 335645 bps, or 327 kbps.
Originally Posted by jrallan26
2005-03-25 18:25:29 EST: 2794 / 236
Your download speed : 2861313 bps, or 2794 kbps.
A 349.2 KB/sec transfer rate.
Your upload speed : 242394 bps, or 236 kbps.
Originally Posted by Yoda
2005-03-25 23:45:16 EST: 3830 / 342
Your download speed : 3922419 bps, or 3830 kbps.
A 478.8 KB/sec transfer rate.
Your upload speed : 351020 bps, or 342 kbps.
Originally Posted by 4-RUNNIN' FREAK
2005-03-25 23:23:57 EST: 2358 / 646
Your download speed : 2414668 bps, or 2358 kbps.
A 294.7 KB/sec transfer rate.
Your upload speed : 662105 bps, or 646 kbps.
From: https://www.yotatech.com/forums/f98/western-wa-comcast-users-reboot-cable-modem-55067/
Old Jun 5, 2005 | 03:33 PM
My wife was the DSL install manager at the CLEC we work for (for 5 years, until she got promoted). She says first thing to check is that you have a filter on every phone line in your apartment. Do you know who the provider to the complex is? Does each apartment have DSL, or does the complex have a single DSL line that they share with all the tenants?
Old Jun 5, 2005 | 03:35 PM
oly884's Avatar
Guest
i don't know who the provider is, nor do i know if each apartment has DSL, I do know that each apartment has a router.
Old Jun 5, 2005 | 03:57 PM
whose the manufacturer & what's the model number on the router? if you can post the results from a traceroute to yotatech we can figure out the provider.
What about the filters? did they give you enough?
Old Jun 5, 2005 | 05:28 PM
oly884's Avatar
Guest
actaully I found a site that helped me out, it's still downloading way slower than the upload, but i think that's just due to the apartment complex.
Old Jun 5, 2005 | 05:29 PM
oly884's Avatar
Guest
it's a d-link 604
Old Jun 5, 2005 | 05:31 PM
oly884's Avatar
Guest
C:\Documents and Settings\David>tracert www.yotatech.com
Tracing route to yotatech.com [82.165.233.29]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 2 ms 1 ms 1 ms 69.51.81.193
3 21 ms 21 ms 15 ms 69.51.112.153
4 11 ms 15 ms 13 ms fe-0-1-3-rf-45m-usb-bzn.mt.core.cutthroatcom.net
[209.137.234.125]
5 16 ms 19 ms 11 ms t3-0-0-3-ta-hln.mt.core.cutthroatcom.net [209.13
7.235.218]
6 18 ms 22 ms 25 ms ge-1-3-0-fh-mso.mt.core.cutthroatcom.net [69.51.
100.178]
7 36 ms 30 ms 35 ms ge-3-0-0.ar2.SEA1.gblx.net [64.209.88.141]
8 50 ms 60 ms 53 ms so1-1-0-2488M.ar1.SJC2.gblx.net [67.17.64.65]
9 55 ms 62 ms 72 ms 208.50.13.94
10 79 ms 62 ms 67 ms sl-bb21-sj-10-0.sprintlink.net [144.232.20.58]
11 62 ms 62 ms 66 ms sl-bb24-sj-12-0.sprintlink.net [144.232.3.202]
12 58 ms 61 ms 64 ms sl-bb21-stk-12-0.sprintlink.net [144.232.20.180]
13 134 ms 122 ms 142 ms sl-bb26-pen-12-0.sprintlink.net [144.232.20.162]
14 125 ms 124 ms 133 ms sl-bb27-pen-15-0.sprintlink.net [144.232.16.94]
15 127 ms 127 ms 139 ms sl-bb21-nyc-2-0.sprintlink.net [144.232.20.96]
16 103 ms 107 ms 111 ms sl-bb24-nyc-11-0.sprintlink.net [144.232.13.185]
17 111 ms 113 ms 104 ms sl-gw30-nyc-0-0.sprintlink.net [144.232.13.20]
18 149 ms 110 ms 117 ms sl-schlu4-1-0.sprintlink.net [144.232.228.6]
19 105 ms 114 ms 103 ms a0nycc2.gw-core-a.nyc.schlund.net [217.160.229.1
04]
20 128 ms 113 ms 104 ms pnycd1.gw-prtr-a.whn.schlund.net [217.160.229.2]
21 122 ms 120 ms 119 ms daniel.digitalcrowd.com [82.165.233.29]
Trace complete.
oly884's Avatar
Guest
Yeah, i know, it sucks.
Old Jun 5, 2005 | 05:55 PM
midiwall's Avatar
Well, the hop count isn't pretty, but the end-to-end time isn't bad. It's actually faster than mine (11 hops, 132ms ping to YT).
Did you reset the router? Is there a modem in the apartment as well? If so, reset it.
If _not_, then is the router just hooked up to a CAT-5 cable that dissapears into the floor? (this is my guess) If so, then ... EEEK! That would tend to say that the apt folks are stringing all the apts off of one DSL connection, which is a LOUSY thing to do. Do they charge you for this access? They'd better not be...
The first hop out of your machine points to an IP range that's owned by:
TransAria
7330 Shedhorn Drive
Bozeman, MT 59718
I do hope that you're at least in Montana and somewhat close to Bozeman? (your profile says that you're down the street from me in Woodinville, which I'm hoping is wrong!)
Has the connection always been slow, or did it just start happening?
Can you please go to a prompt, type "ipconfig /all" and post the results? If this just started happening, then it could be an issue with a slow DNS node.
And please reset the router... It certainly can't hurt.
Old Jun 5, 2005 | 06:14 PM
oly884's Avatar
Guest
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\David>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Oly
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : Yes
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) PRO/100 VE Network Connecti
Physical Address. . . . . . . . . : 00-07-E9-72-BA-C0
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.0.2
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
DNS Servers . . . . . . . . . . . : 192.168.0.1
I'm off at school in Bozeman. So that's a good thing.
The cat-5 cable does dissapear into the wall, so yeah, but the good thing is, it's free internet. However, I'm sure that's why the dl is so slow compared to the ul. oh well.
oly884's Avatar
Guest
Oh, and I reset the router, and updated the firmware to the most recent.
Old Jun 5, 2005 | 06:58 PM
the dlink 604 is a broadband router, not a DSL modem/router so it looks like you are sharing a broadband link. I'd guess that the other tenants are using most of the download speed, and I don't have any good suggestions for how to get a bigger share of that pie.
Well, you could always break in to every other apartment and unplug their computers.
Old Jun 5, 2005 | 06:59 PM
oly884's Avatar
Guest
hahaha, ok, it's good to know that I'm not dsl
