Need Memory Stick Help
Old Sep 13, 2006 | 07:14 PM
dragr1's Avatar
I have a Sony digital video camera that uses a memory stick. It came with a 64mb stick and I bought a 512mb stick. I used the 512 stick once and it worked fine the whole time at Tellico in May.
But, since then the 512 stick has not worked-it just says incompatible memory stick? What's wrong? How do I fix it?
I'd rather not have to go buy another memory stick.
Old Sep 13, 2006 | 07:34 PM
waskillywabbit's Avatar
Sounds like it got de-formatted or something.
Dunno. I got 4 or 5 of those things...don't remember how big.
Old Sep 13, 2006 | 07:43 PM
dragr1's Avatar
How do you re-format?
Old Sep 13, 2006 | 07:50 PM
HellifIknow.
You might try the SONY website as I would think what happened to your memory stick happens often if I were betting...and they would probably have the answer in a FAQ or something...worth a shot.
Old Sep 13, 2006 | 07:51 PM
Cebby's Avatar
Do you have a card reader for it on your computer? If you click on "My Computer", you'll find the stick. You can right click and "format" will be one of the options.
If you only use your camera to connect the MS, plug it in and it will act as a card reader. Same gig as above...
Old Sep 13, 2006 | 07:54 PM
Cebby's Avatar
...as I would think what happened to your memory stick happens often if I were betting...and they would probably have the answer in a FAQ or something...worth a shot.
I've had at least one Sony of one variety or another for the last 11 years. I've never had a MS take a dump...
Old Sep 13, 2006 | 07:56 PM
Talking
Well, if your MS takes a dump make sure to get it on film on another MS. Be worth millions!
Not everyone is as "speshul" as you Cebby!
Old Sep 13, 2006 | 08:08 PM
dragr1's Avatar
Cebby-tried it in the card reader and it never shows up on the computer. It's a Sandisk ms-I figured it would be ok since the camera came with a Sandisk ms.
Uhoh-I think I found the problem! the orginal ms was made in Japan and the one I purchased later was made in China!
Old Sep 18, 2006 | 08:02 PM
breknraj's Avatar
Your camera should have the capability to re-format the stick. You'll have to look through the owner's manual, or scroll through the menus on the camera.
I've had to re-format a couple of my MSs, and it's really no big deal.
Old Sep 19, 2006 | 03:29 AM
dragr1's Avatar
I'll read through the manual b/c it's still not working.
Old Sep 19, 2006 | 04:31 AM
Jonathan's Avatar
Brett, did your camera come with a "memory stick" or a "memory stick pro?" Old sony cameras ran the memory stick, but all the cameras made within the last few years use memory stick pro and they are usually not compatible with older sony cameras. I used to be a manager at Circuit City and we would see this all the time. Other than that, it sounds like the card could have just gotten damaged somehow.
Old Sep 19, 2006 | 04:11 PM
dragr1's Avatar
It came with a memory stick and I bought the memory stick pro. I could see that as the problem-except that the memory stick pro did work at Tellico in May.
Old Sep 19, 2006 | 05:53 PM
Jonathan's Avatar
Yeah that is kinda strange, my only guess is that somehow the card got damaged, but that hardly ever happens, but maybe? Hopefully you can get it figured out.
primordialbeast117
Dec 19, 2015 12:23 PM
irv
Sep 29, 2015 01:04 PM
taraf
Sep 25, 2015 02:57 PM
yoterr
Sep 15, 2015 06:26 AM
