GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
where to mount the cb antenna
Old Sep 14, 2006 | 04:15 PM
yodaboy4life's Avatar
ok well me and my dad are trying to find a place to mount his c/b antenna on his new 02 tacoma ex cab but he has a canopy on it and he does not want it up front becuase he had had it up there for 8 years on his other toyota and got tired of it any sugestions on were a place to mount it is??????
Old Sep 14, 2006 | 04:20 PM
User 051420's Avatar
Mount it on the outside corner of the rear bumper, if the antenna will clear the rear glass.
Old Sep 14, 2006 | 04:25 PM
with what kinda mount do you need somthing special????
Old Sep 15, 2006 | 05:31 PM
Merlin's Avatar
Not really - you can just use a piece of flat bar with a hole drilled in one side that attaches to your rear bumper using existing bumper bolts (they are long enough) and then drill a hole in the other end for the mount.
If you want, you can round off the corners so you don't cut your leg on the corners if you catch your leg or pants on the corners.
If you really want something stronger like if you plan to use a 102" whip or taller coil antenna, you could use angle iron/angle aluminum.
Other than that, it's no big deal at all.
Aloha,
Merlin
Old Sep 15, 2006 | 06:13 PM
crackerjack's Avatar
I'm thinking about a C.B., I've noticed that if you're antenna is too stiff going through the woods it's always being raked back by low limbs. So I'm going with one that has a lot of flex
Old Sep 15, 2006 | 06:22 PM
Localmotion's Avatar
you can get a spring for it
BTW: if any of you guys are llooking for a 4ft firestik, let me know
Old Sep 16, 2006 | 08:13 AM
well it is a 6 ft fire stick and it does have some flex to it not having a spring but this one has a big spring on it and it is 8 years old so it is really flexy and yes it does rack on every thing in the way kinda annoying a 6 ft is kinda heavy soo i would want to use a piece of angle iron or angle aluminum??? i really appreciate your guys help were just trying to get it all figerd out and set up before hunting season so we can take more then one rig less then 2 weeks away soo this is really helpful to us thanks again
Old Sep 16, 2006 | 10:25 AM
Merlin's Avatar
The firestick antennas are pretty flexible (kind of like the Shakespeare Ugly Stick fishing pole). You can almost bend them double (got one caught in a garage door once) and it didn't break. The spring will help absorb some of the shock of hitting it on things to some degree also, so it won't hurt to leave the spring on.
If you plan on catching it on things, you may want to consider using angle iron for increased strength when you snag the antenna. A 6 foot firestick can probably generate a fair amount of leverage on the mount.
Aloha,
Merlin
Old Sep 16, 2006 | 03:12 PM
yea i can bend my fire stick just about in half and im really suprised that it will do that with out breaking and we finally mounted it hooked his c/b up today and it looks alright it works we ended up taking a piece of angle iron about 11 inches long and welding it to the side of the tow package and the drilling two holes for the mount and mounted it on that it looks pretty good i think
Old Sep 16, 2006 | 03:42 PM
ronniedaniels's Avatar
can someone please tell me how to post on here? all i have figured out is this.
Old Sep 16, 2006 | 03:43 PM
can you or someone tell me how to post?
Old Sep 16, 2006 | 10:00 PM
post what you are posting stuff right now
Old Sep 16, 2006 | 10:01 PM
seems like ronniedaniels has met jack daniels
Old Sep 16, 2006 | 10:10 PM
here is pics of the finished product btw it is primer brown becuase i ran out of black paint
live4soccer7
May 11, 2016 06:52 PM
scott90
Oct 4, 2015 09:21 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
voiddweller
Oct 2, 2015 07:47 AM
Brodetski
Sep 30, 2015 11:50 PM
