Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Subwoofer beats to my blinker?
Old Nov 4, 2008 | 07:59 PM
Surfgromdave's Avatar
.....test
Old Nov 4, 2008 | 08:08 PM
olharleyman's Avatar
Grounds
ozziesironmanoffroad's Avatar
you have a bad ground somewhere. go through your system with a voltimeter or a continuality tester, whatever thats called.
Old Nov 4, 2008 | 08:13 PM
.....test
Old Nov 4, 2008 | 08:22 PM
.....test
Old Nov 5, 2008 | 02:31 PM
drpdmazda's Avatar
Originally Posted by Surfgromdave
do you think its the ground from my subwoofer amp? or my head unit? and how do i either fix the preexisting ground or add another ground wire/ what do i do to fix the problem? also, thanks for the quick replies
just reground them both. re ground the head unit to solid metal somewhere behind the dash, but not too far from the actual head unit and check the amp ground, make sure its grounded to bare metal and or a good ground spot sych as a bolt etc.
Old Nov 5, 2008 | 02:41 PM
any ideas?
Reground both of them to the frame each either with it's own or the two together only cut out any common grounds to the battery or frame
Old Nov 5, 2008 | 02:45 PM
cubuff4runner's Avatar
As the other said check all your grounds. If it is still doing it get a ground isolator.
Old Nov 6, 2008 | 07:03 AM
yotakid825's Avatar
it sounds like there are two ground points that are too close to each other. maybe the amp ground is to close to a blinker ground in the rear of the vehicle?
Old Nov 6, 2008 | 07:55 AM
axman667794pickup's Avatar
i would try to reground the amp first, probably not the head unit. run the largest wire you can the shortest distance from the amp, but away from other grounds which may interfere, such as the ground for your blinkers or rear wipers, etc.
and of course make sure ur ground is pure metal on metal contact.
Old Nov 6, 2008 | 05:20 PM
.....test
Old Nov 6, 2008 | 05:30 PM
did it just start after you regrounded the amp?
smilen724
13
Nov 8, 2015 04:11 PM
mreagen
Oct 5, 2015 04:27 PM
Scotttekoch
Sep 28, 2015 10:30 PM
Toys4parts
Sep 26, 2015 01:56 PM
83
18
Sep 21, 2015 06:15 PM
