Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Sub making weird noise!
Old Dec 9, 2009 | 01:55 PM
Cal01's Avatar
installing a HU and 2 amps. everything works fine except when the rear sub is hooked up. The sub pushes up and down but makes a weird sound...the power is coming from a gold block that spit into 2 for the amps...thats my guess..what can it be??? help!
Old Dec 9, 2009 | 01:58 PM
alil2cul4u's Avatar
Is it motor noise? Does it make the noise only when the car is turned on?
Old Dec 9, 2009 | 02:33 PM
Cal01's Avatar
no its not motor noise. its the sub woofer thats making the noise
Old Dec 9, 2009 | 02:43 PM
Windsor's Avatar
Eject that Rick Astley CD from your stereo.
In all seriousness, do you expect us to guess the type of noise you hear?
Old Dec 9, 2009 | 02:48 PM
90runnerfan's Avatar
you sure the subs not blown? also the voice coils could be bad if it is a new or used sub sounds weird though
Old Dec 9, 2009 | 02:51 PM
Elton's Avatar
your subs out of phase ? fancy word for one hooked up backwards
Old Dec 9, 2009 | 02:53 PM
just thinkin again like elton says check that too, but be sure to make sure you have a good ground i had that problem before when i didnt have a large ground cable and a good ground as well
Old Dec 9, 2009 | 03:30 PM
Cal01's Avatar
@ Ricky Astley...I'd be RIcked rolled like a mofo huh. haha
the speaker goes up and down when makes the noise. never seen this before. anyhow, I'm going to check the ground and speaker wire again. thanks
Old Dec 9, 2009 | 06:06 PM
Cal01's Avatar
well I checked and it seems that the speakers are screwed. wasn't ripped before i took them out from my last car but w/e. might of been the wires like Elton said. well, I'm picking up a 12w32v2-d2 JL subwoofer. hopefully these don't up.
Old Dec 15, 2009 | 04:33 PM
Cal01's Avatar
tested everthing and couldn't find the answer. opened up the amp saw some ground that off..used some foil and electric tape and its fixed. lol. thanks all.
cars-guy
Aug 16, 2020 06:59 AM
yourrealdad
Jul 21, 2015 11:13 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
icentropy
Jul 14, 2015 10:23 AM
razorman8669
Jul 12, 2015 12:13 PM
