Tacoma Solid Axle Swap
Old Nov 10, 2003 | 04:03 PM
  #121
runnerboy97's Avatar
i see the axle. this is such a great show, too bad its keeping me from getting anything done.
Old Nov 10, 2003 | 04:23 PM
  #122
its2slo's Avatar
doh :pat: that third members on the wrong side!
Old Nov 10, 2003 | 04:26 PM
  #123
Flygtenstein's Avatar
Are you doing some major reworkin in the transfer case arena, or are 2slo and I missing something. That axle sure looks like one that should go on my 95.
Old Nov 10, 2003 | 04:30 PM
  #124
Shane's Avatar
Psst! Guys! The axle is upside down and backwards...
Old Nov 10, 2003 | 04:34 PM
  #125
Shane's Avatar
GUYS?!?!?!
Old Nov 10, 2003 | 04:35 PM
  #126
i just saw the new pics. what are they thinking?
Old Nov 10, 2003 | 04:36 PM
  #127
Shane's Avatar
Pig goes on the driver's side, kingpin/balljoint thingies tilt in at the top....
Old Nov 10, 2003 | 04:40 PM
  #128
its2slo's Avatar
i was making a joke, thats what the laugh was for. im sure they just want to compress the springs and check the shackles.
  #129
Shane's Avatar
BWAAHAHHAHAA!!!
They must be getting tired...
Old Nov 10, 2003 | 04:52 PM
  #130
its2slo's Avatar
i didnt hear the 6 o clock whistle
Old Nov 10, 2003 | 06:22 PM
  #131
KING's Avatar
I SEE THE AXLE!!!
FINALLY................
LOL!!
Old Nov 10, 2003 | 07:16 PM
  #132
Shane's Avatar
Just talked to Chris, they were just screwing with our minds on the backwards axle thing. The bar they were using to try and check the shackle angles was flexing too much so they had to use the axle instead. Now they're trying to figure out the angles for the knuckles and pinion.
Old Nov 10, 2003 | 07:19 PM
  #133
its2slo's Avatar
i wonder how the short shackles are working?
Old Nov 10, 2003 | 07:57 PM
  #134
WATRD's Avatar
Okay, a chance to update you. I have been fabbing parts all day and haven't really taken a net break.
The spring hangers are all on and the springs are hanging from them. We went with shackles that are 6" hole to hole. Hopefully that will be the right size.
As Shane mentioned, we had to use the axle to compress the springs to see how the shackle angle worked out. Since the axle had perches on the bottom for the original spring under configuration, we flipped it over and used those perches to catch the centering pins. Sorry if we got your heart rate up, we wondered in advance if anyone would notice
ChrisCo is currently fabbing some new spring perches for spring over, JRuz is assembling steering components, look for a photo of steering stuff soon.
I am doing some research on pinion angles and caster angles, under the camera, but I am here. We are still hoping to get the axle under the truck tonight now that we have a plan for setting the correct angles...
Old Nov 10, 2003 | 08:09 PM
  #135
Shane's Avatar
Like I was telling Chris, worry about the pinion angle first so you can get the spring pads tacked on. Then put the full weight of the truck back on it again (hopefully the truck will be level enough...) and set in your caster. This all of course requires that you're turning just the knuckles and not the whole axle tubes. I forgot to ask where you were rotating them, just assumed from the shiny areas next to the knuckles that you were doing it there and not at the diff end.
Old Nov 10, 2003 | 08:17 PM
  #136
WATRD's Avatar
Thats the plan. We are prepping some perches now so we can set approximate angles, then we will set the truck on it and look at angles. THEN, we will pull it all off, set the permanant angles for pinion and caster, then put it on and bolt it all up.
We are turning the knuckles at the knuckle end, not the whole tube Turning the whole tube looked like WAY to much make work...
Old Nov 10, 2003 | 09:41 PM
  #137
Shane's Avatar
eek! The WATTORA garage ghost made an appearance!
If that poor webcam had retinas they would be fried right now. Talk about flash burn!
Old Nov 10, 2003 | 09:50 PM
  #138
WATRD's Avatar
ChrisCo said EXACTLY the same thing when he saw that one.
I was welding on the second spring perch so we can drop the truck on the axle in the morning
ChrisCo says that is the "Ghost of Fabrications Past".
Old Nov 10, 2003 | 09:54 PM
  #139
Shane's Avatar
Old Nov 10, 2003 | 10:02 PM
  #140
WATRD's Avatar
