PSC full hydro
Old Jan 18, 2010 | 06:17 PM
lbyota85's Avatar
PSC full hydro
Well after a few years of running the "home made" X-over steering I finally reached the limit of the stock arms and they started to crack at the stud holes, so I decided to get myself an early Christmas gift. I calld up Brandon at RIDES and had him get me a full PSC hydro kit. I got it all put on and took a few pics of the install.....
Pump
Steering valve and mount....
Tank...
Attached Thumbnails PSC full hydro-pump.jpg   PSC full hydro-valve.jpg   PSC full hydro-tank.jpg
Old Jan 18, 2010 | 06:22 PM
lbyota85's Avatar
I tried to make most of the stuff bolt on so I drilled and sleeved the front truss so I could bolt on the ram mount......
I cut the ram mount out of 1/4" alu. and bent it up in the press at work...
I also cut some gussets for the bottom of the plate and miged them on....
Attached Thumbnails PSC full hydro-truss.jpg   PSC full hydro-plate-ram.jpg   PSC full hydro-under.jpg
Old Jan 18, 2010 | 06:27 PM
lbyota85's Avatar
Once I got that all worked out and plumed I put on the new high steer arms from Marlin Crawler and made the tie rods...
I added some brake line mounts to the arms as well as cut down the pass. side arm
I got a Turtle head.
The ram ended up being offset to the driver side a little so the tie rods are different lengths...
Attached Thumbnails PSC full hydro-arm.jpg   PSC full hydro-armclose.jpg   PSC full hydro-tierods.jpg
Old Jan 18, 2010 | 06:39 PM
lbyota85's Avatar
Got the tie rods on and got every thing bolted up...
Went over to MUDPRO metal works and bent out a ram guard made out of 1.75" .1875 wall DOM and welded a flange to bolt the front face of the ram mount.....
Got that all welded up and put on.....
Let me know what yall think. Thanks. New guy here.
Attached Thumbnails PSC full hydro-done.jpg   PSC full hydro-guard.jpg   PSC full hydro-picture-091.jpg
Old Feb 2, 2010 | 09:57 PM
907-4runner's Avatar
is that a custom fourlink or was that a kit? who did the work on thats nice!!
Old Feb 4, 2010 | 09:11 PM
agusgus3's Avatar
Thats pretty sweet man! I like the brake line holders, the aluminum tray and your mig AL welds, look pretty good too, I'm horrible at mig AL, I'll take a tig anyday...
Yeah four link up front is pretty interesting! how much lift is that and tire size?
Old Feb 19, 2010 | 01:56 PM
lbyota85's Avatar
No, not a kit. Thanks, I did all the fab work.
Thanks. I did all the MIG with a Miller 350P on pulse, it's pretty sweet to use. I dig TIG too but it was just quicker to do it that way. This is a pic of the fuel tank I built for it......
As far as lift height it's about 3" on 38.5s. I ended up sliding the front axle up 13" and the rear up 3" so I have a 112" WB with exactly 50/50 weight distribution from front to back. Here's a pic of some of the travel..... Oh and here's my build thread on my local forum. LINK
Old Feb 20, 2010 | 02:56 PM
agusgus3's Avatar
major props man, its tough to run a bead that long, especially in alum and still have it look good. Just started on your original thread, but its time to go to work...damn
sweet rig man
83yotastockR
11
Nov 10, 2015 06:54 AM
smilen724
13
Nov 8, 2015 04:11 PM
Dale Johnston
11
Oct 31, 2015 10:22 PM
Obmi
Oct 4, 2015 11:30 AM
tylermx71
Sep 29, 2015 08:49 PM
