IFS in a 83
Old Oct 17, 2013 | 03:19 PM
R.DesJardin's Avatar
IFS in a 83
Anyone every put an IFS setup in their first gens. I just picked up a Supra diff and axles and am eyeing the whole IFS thing and liking it. Always been a little off, but the IFS would be cool with a trailing arm linked rear.
Size:  3.37 MB Name:  IMGP0896.jpg
Old Oct 17, 2013 | 03:25 PM
HighLux's Avatar
I doubt if any one has ever done that. Like putting a prop engine in a f16 fighter.
Old Oct 17, 2013 | 04:59 PM
Well I knew this would bring out the naysayers, but I still think the flex forklift ravings are hype in 90% of wheelin. Beside I'm looking more toward better control on the rough stuff that I've seen around here and more clearance in the PNW snow. Don't forget I run an A340 dual cases and a 2RZ all the parts no one likes. Silly people.
Besides I wanna be like Shannon!
Old Oct 17, 2013 | 05:39 PM
dropzone's Avatar
Fossilized
Now if you built an 8" center section that would be really cool
PNW Snow? are you moving back?
Old Oct 17, 2013 | 05:40 PM
Teuf's Avatar
Have fun, good luck.
Old Oct 17, 2013 | 06:05 PM
Not right away but I shall return be fore I'm too old an gray.
I've read up a bunch on this setup using the Supra diff I have. Shouldn't have issues. The Aussies do stuff like this all the time.
Oh I'll have fun and I don't need luck, I'm that good.
Old Oct 17, 2013 | 06:12 PM
Discombobulated's Avatar
I wanna see it when it's done
Old Oct 17, 2013 | 06:29 PM
Teuf's Avatar
Ya know, me too..........
Old Oct 17, 2013 | 06:33 PM
4x4YOTA's Avatar
do it be the first... i have thought about swaping a 1st gen cab on a new IFS frame but a custom setup would be better
Old Oct 18, 2013 | 10:54 AM
Teuf's Avatar
My IFS deteriorated to the point that a SAS was cheaper. I like the ride with leaf springs.
Old Oct 18, 2013 | 11:00 AM
HighLux's Avatar
The aussies do some pretty weird stuff dont they? Obviously you could fab this up...your confidence tells me that. I understand wanting to be unique and push the boundries....what I dont see is the benefit.
scribble me a picture of what this would look like. Like a long travel ifs front set up in rear? offset or centered?
Old Oct 18, 2013 | 03:19 PM
Thanks and OK benefits/my opinions:
I think I can get more overall ground clearance with IFS, definitely more to the diff at ride height for sure. This will help with any wheelin I've done.
IFS handles better at most speeds over a crawl.
Big Flex especially overflex is a fad and 90% of us don't need it. I think the Ultra4 cars have this figured out. But this is an opinion and can't be argued so let's leave it alone. I drive Toyotas, Dodges and I like guns, can't argue any of this it's who I am.
Flexy rigs are tippy, I like hills and bumps.
Not looking for more travel that the solid axle setup I have has, I'm running RUFs and have plenty of travel.
Centered diff.
CAD images will follow as I continue.
Old Oct 18, 2013 | 04:13 PM
HighLux's Avatar
So more like a trophy truck set up. I get it.
Old Oct 18, 2013 | 04:25 PM
donomite49's Avatar
check out blazelands center diff mount kit. 15 to 16" of 4wd travel...
http://blazeland.us/cmdiff/
it will be very unique and different.
going long travel front and rear?
Old Oct 18, 2013 | 04:41 PM
I've seen what Blazeland has got going. I'm setting up travel to coincide with the current ride height I have, don't really want taller if I can stay were I'm at. Then its how far the diff guard is from the ground for up travel and what ever I feel I need for droop.
Not trying to get super long travel I was planning on 12"ish front and maybe 14" rear using trailing arm lowers and triangulated uppers. I did this 25yrs ago on a short track racer. Worked good, handle good at 60mph in the dirt.
Old Oct 18, 2013 | 07:13 PM
donomite49's Avatar
12" travel on the front will be easy with blazeland or a total chaos kit.
Chevy 63's on the back should get 14" or so travel without shocks going through the bed.
Keep in mind that with a blazeland or chaos front kit you use t100 axles so you will need a wider rear axle to match the wider track width.
I plan on using a t100 rear axle and using the space outside the frame for shocks going through the bed to a bedcage on the front part of the bed so I can still use my bed for truck duty.
Got to haul the YZ and everything else when I don't want to pull a trailer.
I plan on running some deavers spring under axle with 18" of travel.
Old Oct 18, 2013 | 08:02 PM
Ok here is the truck as we know it, 2RZ, A340, Duels, lockers, 63's, RUF's, plate bumpers front and rear, I 've got a build thread here and on Pirate. This isn't a pretty truck or a DD that I need to worry about getting be back and forth to work. It's built to wheel, it needs to be built different to suit what I do. It's all been done by me a crazy old grey haired grandfather but not quite as old as Marlin.
Blazeland does not make a kit that will do what I want out of this setup nor does anyone else, I have the Supra Diff and Supra axles for the inners and centers and will swap out the outers from an IFS truck. Only time will tell.
Size:  64.6 KB Name:  IMGP0862.jpg
Old Oct 18, 2013 | 08:06 PM
HighLux's Avatar
Super awesome truck!!
Old Oct 18, 2013 | 08:08 PM
HighLux's Avatar
And you don't have a monopoly on the gray hair....well mine is "silver" @ 43.
Old Oct 18, 2013 | 08:27 PM
donomite49's Avatar
I'm just now building my truck, will be 55 this month and still rock my 08 YZ 450...
Nice truck btw.
