Custom Bumper D Ring Question
Old Nov 11, 2010 | 11:08 AM
Bugzman's Avatar
so I have started to build my own bumper and have come to the very end of the project with just the finishing touches. but i have been getting all different answers when it comes to making my D ring mounts. what I am wondering is what thickness of material should I use? I haven't bought D rings yet, so there really is no limitations. I have no idea where to start. some people have said go with 1inch think bar stock others have said 1/4 inch.
any advice will help.
Old Nov 11, 2010 | 11:10 AM
xxxtreme22r's Avatar
most of the aftermarket premade ones are made out of 1" bar, why not just use them. ?
Old Nov 11, 2010 | 11:13 AM
BigBluePile's Avatar
Well, what you could do is stack the 1/4" plate up and weld it all together to make a solid mount. That way it'll be easier to make the hole for the actual d-ring(which is 5/8" IIRC...)
Old Nov 11, 2010 | 11:14 AM
Bugzman's Avatar
I have custom made everything else so far. I just though those could be made too.
You can make them, easy peeezy
Old Nov 11, 2010 | 11:15 AM
they could be made, but hella hard to drill though 4 pieces of 1/4" let alone a 1" plate. Hope you got a darn good plasma cutter to cut a 1" bar too. lol.
Old Nov 11, 2010 | 11:26 AM
You could do it in 1/8" plate...
If you have a good step up drill bit, it's a BREEZE to shoot holes in 1/4" plate. Just make sure you fire a good pilot hole first.
Old Nov 11, 2010 | 12:34 PM
Bugzman's Avatar
i have some 1 inch bar. Ill just take my time and try to just do like 5 steps on drilling it out. thanks for the help.
Old Nov 12, 2010 | 12:24 AM
wyoming9's Avatar
Red face
No matter what size you make these things they are only as good as the attachment to the vehicle . I understand all to well trying to figure the load on winching a 80,000 pound truck sunk to the axles in the mud
I work with lifting and pulling things all day .
Make them anyway you like heck 3/8" is plenty
I just use the 2" receiver hitch mounts back and front.
If you want mount 3 on the back one each side and the middle for pulling trailers
If you need the shackles to pivot up and down you can drill a hole 90 degrees to allow the shackle to pivot in that direction.
bigjstang
Jun 2, 2025 03:56 PM
icentropy
Sep 16, 2020 02:47 PM
Sep 4, 2015 09:27 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
