A bit different hood scoop
Old May 23, 2011 | 05:42 AM
  #61
E-ROC's Avatar
now thats funny!
Old May 27, 2011 | 05:41 AM
  #62
E-ROC's Avatar
so far so good. the hose hasnt melted. no noticable performance gain which i never expected anyhow, and i get a slight whistle sound from the air going thru the expandable hose. doesnt bother me though. now to create my own front leaf spring packs.
Old May 27, 2011 | 07:23 AM
  #63
tlrskunk's Avatar
E-roc Have you noticed a decrease in engine temps? That is normally a benefit of a hood scoop due to the extra air flowing through the engine bay.
Old May 27, 2011 | 06:06 PM
  #64
E-ROC's Avatar
the air goes directly into the air intake box and does not flow onto the motor itself. as far as toyota motors go anyhow, they usually run at the normal temp no matter what you try to do to them. if you want cooler operating temps try using a lower thermostat. maybe that will help.
Old Jun 2, 2011 | 09:59 AM
  #65
E-ROC's Avatar
it wasnt the hose whistling, it was my belt tensioner going out. oh, and there is no signs of rubbing on the bottom of the elbow. guess its time to put a little silicone on to seal up the connections good.
Old Jun 2, 2011 | 07:27 PM
  #66
modlite's Avatar
Wait, this hood scoop has to be functional. Isn't it essentially a cold air intake? I mean the airs not having to run through the fender or anything just through the hose and into the box.
Old Jun 3, 2011 | 04:03 AM
  #67
an1mal_69's Avatar
Nice work..hope you installed a new filter tho, flipping the old one will jus clean out the months of crap into your motor
Old Jun 3, 2011 | 06:08 AM
  #68
E-ROC's Avatar
yeah it makes it a cold air intake since the air comes from outside of the engine compartment. and i cleaned the filter before i put it back( its k&n ).
4x4-runner
Apr 18, 2017 09:08 PM
raptor510
Feb 17, 2017 07:11 AM
g3bill2
Aug 7, 2015 07:04 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
raiderhawks00
Jul 8, 2015 06:23 PM
