THE 1 MILLIONTH SAS (on my 92 runner)
#221
#222
#223
A little off topic, but with those sliders (all-pro right?) Do they look good with only 33's? I want to get a pair for mine but, just wonder if the kickout sticks out too far with that size tire
#224
#226
The rear suspension at that point was 1.5" All Pro coils (which provided no lift, it just leveled the truck) some 2.25 spacers, and disconnected sway bars, and 4" longer shocks.
#227
Yea i was gonna say that the rear end flexes way more than mine. I have some Landcrusier coils that i am going to throw back there but i am not sure about the length of shock i need.
Again, i really want to get those sliders, i might order some soon. still not sure.
#229
I wish I had a 3.4 in that runner. the 3.4 swap I did was in my buddies 92 runner.
Oh and I have NOOOOO $$ Im a poor college kid I recently started working so I decided to SAS.
If I dont sas Ill just waste money on chili cheese dogs and beer then Ill be poor, fat, and STILL on ifs.
Hahaha. LMAO, i just read this, and im in the same boat! Hahaha, thats going in the sig!
#231
Inchworm Auto Adapter?
Just curious if you did the install of the Inchworm dual case for your auto? I have cases built for my auto and wondering how tough the install of the adapter from Inchworm is. Is there a build thread for it? Love the 4runner and all the work done to it, I have followed the build thread since the start.
Thanks
Thanks
#234
Thanks
Thanks
Yes I did the install of the IW adapter. Its not too bad. Its a nasty dirty job and stressful if your not comfortable in an auto. Let me know what you want to know.
I should say I did blow that trans somehow while I was in there. I think its because the first time I put it togeather I didnt line up the tab on the shifter lever with the notch on the piston, and the piston was all the way to the front of the oil pan and I beleive that allowed fluid flow to all gears and engaged all of them. I realized something was wrong becasue I could spin output flange while the truck was off but as soon as I turned it on the flange was locked in all gears. I beleive that did the damage that later took out the trans. When it went out I decided to just do a 3.4 swap and run the a340f and used the marlin adapter to mate up the duals.
#237
ok, i know this is an old thread but what kind of ifs lift did you have on that? i dont have the money for a sas right now but i would like a lift and i love how yours sat with the 35" at's
#238
I like auto better for offroad, more control, even power, always in the right gear, never have to shift midway up a hill, I can stop on a scary obstacle and I wont move and I can start moving again without using 3 feet, oh and did I mention CONTROL!!
My DD is a stick, so I get my onroad fix there.
#239
The rear was 1.5" AP coils which didnt lift me at all so I got some 2 1/4" coil spacers as well and I had a rake.
while I dont beleive I would run that setup again, It should be said that from the begining I planned on SAS'ing and planned to run the IFS into the ground.
BTW mini-truck ifs is way under rated! I cosider it to be, pound for pound, one of the strongest IFS's out there. I beat mine for years and never broke a cv, I just kept a steady supply of Idler arm bushings handy, which at .94 cents a piece from toyota I didnt mind. I got to the point that I could change the bushings in a parking lot in about 2 min.
