Post Your Tests Here Use this sectin for testing your signature files, and for testing pictures/avatars
22RE ran without oil! 😕
Old Mar 14, 2019 | 03:22 PM
Johan2712's Avatar
Hi everybody,
So, remember I said I was going to replace the connecting rod bearings? So I did it and the knocking is gone, the engine start right up, and run smooth but after a minute die, it is running and all the sudden just stops.
I'm glad I didn't f...ed it up by run it low in oil but now I have to deal with something different, any idea?
I jumped to check for codes and the check engine light blinks continuesly, so no codes? 🤔
Last edited by Johan2712; Apr 1, 2019 at 12:15 PM. Reason: Fixed it up but have a different issue
Old Mar 14, 2019 | 04:58 PM
akwheeler's Avatar
It's done, time for another rebuild. Oil changes and checking the dipstick are cheap insurance.
A new engine will burn oil until it seats the rings and you should always change the oil at 500 to 1000 miles after a rebuild anyway.
Old Mar 14, 2019 | 05:13 PM
old87yota's Avatar
Akwheeler is right.
Unfortunately, you have no way of knowing the damage caused by running low on oil unless you take the engine completely apart and inspect all parts.
I wish we had better news.....
Old Mar 14, 2019 | 05:37 PM
Discombobulated's Avatar
So did you have oil in it and it leaked out? Or?????
Old Mar 14, 2019 | 06:34 PM
Johan2712's Avatar
I completed the rebuilt 3 weeks ago, and then put super tech 5w 30 from Walmart and lucas stabilizer, I really don't know how good or bad that oil is, but today I found out the dipstick showed nothing, it looks like the oil just evaporated, I have no one drop leeks, all gaskets new, pistons, rings, valves, new timing kit, even new front cover.
Old Mar 14, 2019 | 06:36 PM
Johan2712's Avatar
Originally Posted by old87yota
Akwheeler is right.
today I drained the oil I put today, tomorrow I will remove the oil pan and inspect it from underneath, hopefully I just have to change the connecting rod bearing, wish me 🤞
Old Mar 14, 2019 | 09:01 PM
akwheeler's Avatar
I would wish you luck, but I don't believe in wasting time or mincing words, your cylinder walls are very likely scored, your cam has now eaten it's way into the head, the rockers have scored the cam.
Once there is no oil pressure the damage starts, once you hear the first knocking sound you are in for bad news, once it gets to the point that something very angry wants out there is no turning back. Once you continue driving with angry innards until the engine quits...
you are lucky it didn't just blow a hole in the side of the block.
samx227
Feb 10, 2015 08:27 PM
TheOrangeBomber21
Jun 27, 2011 07:39 AM
dwnhiller93
Jan 29, 2010 05:24 PM
chadbobb
Aug 17, 2006 02:40 PM
WildHare
Nov 14, 2005 02:42 PM
