22re ran out of oil...
Old Feb 9, 2015 | 06:56 PM
samx227's Avatar
my oil pan was leaking so i resealed it. got frustrated and forgot to torque my drain plug. drove to the girlfriends house and parked and smelled oil. looked under my truck and oil was still pouring from the drain plug. it put about 1 1/2 to two quarts on the ground where it was parked so it didnt necessarily run all the way out before i shut it down. i could see my oil trail and i walked it and it was about 400 feet. never found my drain plug so went and got a new one and some oil threw it in and it sounds fine.EXCEPT for a knock noise in the top end. i re adjusted the valves and still no difference. it is audible from inside the cab only when the heater and radio is off so it is quite faint. anything else to check? appreciate it thank you
Old Feb 10, 2015 | 02:39 AM
wyoming9's Avatar
Red face
Possible you starved one of the cam Journals not much you can do unless you want to pull it all apart.
If it gets worse then figure out what to do.
These things happen blame it on your girlfriend
Old Feb 10, 2015 | 08:27 PM
samx227's Avatar
hahaha thanks wyoming9, if the sound gets worse or louder i guess ill worry about it then!
jasonty
41
Dec 23, 2018 01:00 PM
Doug4320
Mar 24, 2018 10:11 PM
montanatruck
Feb 26, 2017 07:07 AM
polo451
13
Nov 20, 2016 07:49 PM
jake_v
Jul 22, 2015 03:17 PM
