Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
Big Noise Manufacturing BNM 1st custom bumper! Give us feedback.
Old Mar 6, 2012 | 05:45 AM
  #141
racerflea's Avatar
Originally Posted by waskillywabbit
I'm a practicing mechanical engineer and 6 bolts won't hold it on for winching.
Reinforce the front frame crossmember with a plate (welded on) then bolt on, side braces and attach through body mount. Weld it on in several spots. Then it still might bend/fail.
Winching puts ENORMOUS loads on a front bumper.
:wabbit2:
Not doubting you i like ur work but my warn winch mount for my 89 only had bout 6 bolts on it not the strongest design( weak braces) but it took a 8k wench fine....
Old Mar 6, 2012 | 08:03 AM
  #142
Leviticus6432's Avatar
Did the winch mount bolt up through the same 6 holes?
Old Mar 6, 2012 | 08:37 AM
  #143
racerflea's Avatar
Not sure of the holes bnm is using but it used 2to factory holes on bottom if frame rails and 2i others that i cant remember where they were trucks at my dads or i would see if i could find them wanna say the were a b!tch to get to though
Old Mar 6, 2012 | 08:43 AM
  #144
racerflea's Avatar
So its no longer on wanr website "the mount" so i cant find any setails on it bummer...
Old Mar 6, 2012 | 01:23 PM
  #145
BNM's Avatar
BNM
Sounds like I should do some FEA testing to double check where the weakest points are.
Old Mar 7, 2012 | 06:45 AM
  #146
BNM's Avatar
BNM
I ran through a few simulations for the bumper and did add make a few changes such as adding an extra piece to help it resist any torque created by the receiver tube being higher then the mounting area. The picture here shows how it would fail if it were to. The deformation is greatly exaggerated to make it clear. The colors though shows the amount of stress in the steel if there was a 8000 lb load pulling from the hitch tube. In this case I am not close to the point at which the metal could fail (yield stress). My lowest factor of safety (like a safety cushion for designing for the what ifs) is around 1.5 which I was hoping to be higher. Because people can and do anything possible to a Toyota I am going to add at least one if not two more mounting points on each side.
Old Mar 7, 2012 | 06:52 AM
  #147
waskillywabbit's Avatar
Now test it with the pull coming completely normal to the bumper, not axial and double your load.
In theory, theory and practice are the same.
In practice, theory and practice are different.
In theory, nothing works but we know why.
In practice, it works but we don't know why.
When theory and practice come together, nothing works and we don't know why.
:wabbit2:
Old Mar 7, 2012 | 07:39 AM
  #148
BNM's Avatar
BNM
:wabbit2:
^^ X2.. I am no theorist. That is why I am studying manufacturing.
I am going to put 1 or 2 more mounting points to it and then Ill put it to the test.
I am probably missing something but it looked like this winch bumper you make on your website uses the same six mounting points? Have you ever had any troubles with it?
Old Mar 7, 2012 | 07:50 AM
  #149
Finite Element Analysis is theory.
Yep, snatched it clean off a truck when dude tied the tow strap to the top of the stinger. Not my truck. Bumper was bolted and welded on.
I'm just warning you, you try to make it idiot proof and you'll find a better idiot that will tear it up anyway.
I always beef mine up and weld them on in addition to bolting. Bolting them on just makes it easier to weld
:wabbit2:
Old Mar 7, 2012 | 08:42 AM
  #150
YOTA SMURF's Avatar
love it..would try adding a stinger and myb fog lites just for more options..but def love it
Old Mar 7, 2012 | 08:56 AM
  #151
racerflea's Avatar
That's the problem with stingers and light hoops idiots tend to hook to the first possible thing.... thats how i lost my mount.... couldnt exit my truck and a idiot snatched me out by my light hoop... oh well maybe i should hace tried harder to get to my front.... but i dont run with them no more so no worries!
Old Mar 7, 2012 | 09:04 AM
  #152
dropzone's Avatar
Fossilized
Originally Posted by BNM
I have thought about it. That will be next on the list. Here are a couple of my thoughts for one. The second one is the one ill probably go towards.
Any suggestions?
old, but i would suggest more wrap around quarter panel protection with mounts to the frame...
edit: with regular 3/4" D-Ring mounts instead of the rings you used on the front bumper...
Old Mar 9, 2012 | 07:30 AM
  #153
BNM's Avatar
BNM
Rodger on that one dropzone. As soon as I can Ill be making a couple prototypes for the rear. Only two more weeks till I am set up in my shop and I can finally get to buildin!
Old Mar 9, 2012 | 07:34 AM
  #154
YOTA SMURF's Avatar
98 Toyota 4runner prerunner lite bar
I been looking everywhere for a pre runner style lite bar for my 98 4runner..any suggestions???
Old Mar 10, 2012 | 09:48 AM
  #155
BNM's Avatar
BNM
I haven't looked into them much and I'll probably not be doing much with tube right now but hopefully some tube bumpers and whatnot will be something that I could do down the road.
Old Mar 10, 2012 | 04:12 PM
  #156
jay604's Avatar
Any chance I can get the cad program for the front bumper, I just started up my 85' 4runner build.
Old Mar 13, 2012 | 08:46 AM
  #157
bsbaker's Avatar
I love the bumper and especially how it drops to cover the radiator but not too low to hide the tow hooks it for sure needs a winch mount, and holes for 3 6inch Hellas if you as me
Old Mar 13, 2012 | 09:44 AM
  #158
BNM's Avatar
BNM
Thanks man. Leaving the tow hooks out was one thing I wanted. I have to redesign it for a winch. It is too low profile right now for one to fit behind it as it is. You want 3 holes for 6" lights?
Old Mar 13, 2012 | 09:46 AM
  #159
racerflea's Avatar
Why 3? 4 would make nore sense huh?
Old Mar 13, 2012 | 10:26 AM
  #160
where would you even put a 3rd one lol
