TrueTrac vs. Locker
Old May 6, 2003 | 03:42 PM
Glenn's Avatar
TrueTrac vs. Locker
Hi
If you had to choose either A or B, what would it be, and why?
A) TrueTrac limited slip differentials both front and rear.
B) Rear locker.
This is for the kind of wheeling that YOU do. What would work best for you?
Old May 6, 2003 | 03:45 PM
joez's Avatar
for me, it would be B. i dont just do mud, so i would rather have the rear locker.
Old May 6, 2003 | 04:56 PM
azrain's Avatar
Locker.
Less money, less hassle and more predictable off road.
IMHO, the LS combination could potentially put the vehicle back in a mode of two wheel drive in different situations. Also, the LS needs an additive or special gear lubes.
Locker, although noisy on the street, is going to give you 99% surety of a locked rear axle off road.
If there was a third choice and funding was available, selectable is now the way to go these days. In other rigs I have had LS and a few Detroit Lockers, the ARB that I have in my 4Runner is sweet. I feel like Daniel-San off road "lock on, lock off, lock on, lock off".
Mike
Old May 6, 2003 | 05:23 PM
Glenn's Avatar
TrueTrac's don't need any special additive or oil. They are gear driven, and use the same oil that any open differential uses.
Old May 6, 2003 | 05:29 PM
azrain's Avatar
Yes, I tend to generalize sometimes.
A combination that I think would be the middle ground between two LS and two lockers would be the LS up front and a true locker out back. Then again, I live in AZ where for the most part, icy / snowy roads don't make such devices a consideration for the most part.
Still, I have to say, rear locker between the two choices...
Mike
Old May 6, 2003 | 06:50 PM
Marc P's Avatar
I love my Detroit locker..very predictable on the road, and not a slip in the rear tires off road.
B would be my answer without hesitation
Old May 6, 2003 | 07:20 PM
L33T35T 4Runner's Avatar
is the detroit soft locker the same as the Lockright locker?
Old May 6, 2003 | 07:45 PM
seafarinman's Avatar
The detroit locker is a carrier replacement locker which means that you have to have a shop install it($$$) since it involves removing the ring gear and attaching the ring gear to the soft locker case. The Lock Right or even the Detroit EZ Locker install inside the factory carrier case so you do not need to remove the ring gear from it.
Old May 10, 2003 | 04:53 PM
Bighead's Avatar
That is what phong is currently running (True-Trac front / Toyota E-Locker rear). If anybody has any questions about that combo they should contact him.
ashamsuddin
17
Jul 22, 2024 03:59 AM
TheBFA
Feb 15, 2020 06:55 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
Toys4parts
Sep 26, 2015 01:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
