Is there a way......
to tell if different gears have been put into the front and rear end? I just bought this truck which has 31's on it so i doubt it's had anything like gears done to it but is there any test or something to tell if it has the stock gears? What are the stock gears on a v6 89' yota pickup btw?
To make sure you have the same ratio in the front back you only have to push the vehicle in a strait line on a flat surface with the engine off and the 4WD engaged. If you can push it without the resistance of the vehicle building up or even coming to a full stop, you should have the same ratio.
If it starts to bind you'r f...d.:pig:
For the ratio use 4crawlers link.
counting teeth is the best way but then u have to take out ur 3rd member! blah!
if you do count, its just the # of teeth on the RING divided by the # of teeth on the PINION.
or click here for a calculator
