Is there a way......
Old Oct 17, 2003 | 05:50 PM
jrobbie4499's Avatar
to tell if different gears have been put into the front and rear end? I just bought this truck which has 31's on it so i doubt it's had anything like gears done to it but is there any test or something to tell if it has the stock gears? What are the stock gears on a v6 89' yota pickup btw?
Old Oct 17, 2003 | 05:56 PM
Cebby's Avatar
You need to look at the sticker in your door jamb. It will say something like G144. That refers to the gearing. Let me find the link to the gearing chart...
Old Oct 18, 2003 | 07:17 AM
4Crawler's Avatar
Find out what ratio(s) you have
Find out what ratio came in the truck
Old Oct 19, 2003 | 04:27 AM
4runner4ever's Avatar
To make sure you have the same ratio in the front back you only have to push the vehicle in a strait line on a flat surface with the engine off and the 4WD engaged. If you can push it without the resistance of the vehicle building up or even coming to a full stop, you should have the same ratio.
If it starts to bind you'r f...d.:pig:
For the ratio use 4crawlers link.
Old Oct 20, 2003 | 09:07 PM
joshik's Avatar
yeh i did the pushing thing too. just be sure to push it some distance like a few miles! JK! :
nawh, but i pushed it so i got a few full rotations of the tires.
Old Oct 23, 2003 | 04:00 PM
count teeth
Old Oct 23, 2003 | 04:04 PM
joshik's Avatar
counting teeth is the best way but then u have to take out ur 3rd member! blah!
if you do count, its just the # of teeth on the RING divided by the # of teeth on the PINION.
or click here for a calculator
Old Oct 23, 2003 | 04:10 PM
anthony1's Avatar
If the gears are different it should jerk...
try it in the dirt though...
hross14
Jul 18, 2008 09:16 AM
