Spacers
if you mean suspension spacers, no you dont need to touch your steering. if you mean body spacers ( body lift blocks ) yes you would need to add an extension to the steering shaft if you do a 2in or greater, but for a 1in body lift i dont BELIEVE the steering stuff is needed
I know for 3rd gens at least, Roger Brown says you'll need a steering shaft extension even with just a 1" body lift.
More info on his site.... http://4crawler.cruiserpages.com/4x4...yLiftKit.shtml
The only thing you need to replace are your shocks. Just did a temporary 2" coil spring spacer on mine. Took two people, air tools, a spring compressor and about 30 min tops. CAUTION: If you do this yourself, the spring are under a lot of tension and could potentially knock out all your teeth or cave in your skull.
FS[MidWest]: 1.5" ball joint spacers
4x4YOTA
Aug 23, 2016 09:08 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
4runnerFireman
Sep 29, 2015 06:24 AM
FS[SouthCent]: TX - 4Crawler Ball Joint spacers
crash813
Sep 27, 2015 07:15 AM
