Spacers
Old Jul 17, 2003 | 08:21 PM
fooddude's Avatar
Spacers
if i got say 1 inch spacers would i have to put any extensions on anything such as steering etc....
Old Jul 18, 2003 | 05:12 AM
crawler#976's Avatar
assuming you mean coil spacer? no-
Old Jul 18, 2003 | 05:43 AM
mtnbkr's Avatar
Speaking of 1" coil spacers, what's the pros/cons and what, if any, changes would one need to make to the rest of the vehicle if they were used...
Thanks,
Chris
NCSU-4runner's Avatar
if you mean suspension spacers, no you dont need to touch your steering. if you mean body spacers ( body lift blocks ) yes you would need to add an extension to the steering shaft if you do a 2in or greater, but for a 1in body lift i dont BELIEVE the steering stuff is needed
Old Jul 18, 2003 | 07:45 AM
TDiddy's Avatar
I know for 3rd gens at least, Roger Brown says you'll need a steering shaft extension even with just a 1" body lift.
More info on his site.... http://4crawler.cruiserpages.com/4x4...yLiftKit.shtml
Old Jul 18, 2003 | 10:23 AM
jx94148's Avatar
Maybe he means wheel spacers or throttle body spacers.
Old Jul 18, 2003 | 07:57 PM
fooddude's Avatar
sry for the confusion guys i meant coil spacers
Old Jul 18, 2003 | 09:58 PM
jx94148's Avatar
OK. No, but you should have it aligned after install.
Old Aug 5, 2003 | 06:34 AM
The only thing you need to replace are your shocks. Just did a temporary 2" coil spring spacer on mine. Took two people, air tools, a spring compressor and about 30 min tops. CAUTION: If you do this yourself, the spring are under a lot of tension and could potentially knock out all your teeth or cave in your skull.
4x4YOTA
Aug 23, 2016 09:08 AM
89YodaRunner
Sep 30, 2015 02:18 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
4runnerFireman
Sep 29, 2015 06:24 AM
crash813
Sep 27, 2015 07:15 AM
