Solid Mounts Good or Bad Idea?
Old May 25, 2010 | 07:31 AM
CurleysRacecars's Avatar
Hey all,
I was looking at the Total Chaos solid motor mounts, and transmission mount/crossmember. I couldnt believe the price on these. I was wondering if these were something 4WD/mud/rock guys would benefit from or are they intended for the sand/long travel type of guys?
Just curious. I know TC does alot of stuff for the long travel guys. Are these worth the money or no? Im thinking about putting together a kit, which Im hoping would be much cheaper than what they sell theirs for.
Any input is appreciated! Thanks!
Kyle
Old May 25, 2010 | 07:35 AM
Swimmerboy2112's Avatar
The solid motor mounts will keep your engine from rocking back and forth while accelerating and decelerating. Essentially they stop your engine from slamming into the firewall when under WOT (wide open throttle). They will also make your truck run a little more rough as the solid motor mounts transmit engine vibrations much better than OEM or poly motor mounts.
Old May 25, 2010 | 07:39 AM
I think the TC engine mounts utilize a poly bushing in the mounts, so I guess they arnt "solid". Is there a market for these in the off-road world though, or just in the sand/long travel guys?
Kyle
Old May 25, 2010 | 07:44 AM
waskillywabbit's Avatar
Lots of folks already make such mounts beside TC. You won't get rich off of it.
Old May 25, 2010 | 07:59 AM
Not looking to get rich...just make a few bucks. Who else makes a complete kit like TC does? Id like to check out others designs. Are these being used in the mountains...or usually in the sand where people are WOT often?
Old May 25, 2010 | 08:05 AM
4Crawler's Avatar
Seems the popular setup is to run at most one poly motor mount, leave the stock rubber one on the other side, unless you are building a dedicated off-road buggy. A simple chain across the motor mount can also "do the trick":
- http://www.4crawler.com/4x4/CheapTri...torMount.shtml
Old May 25, 2010 | 09:01 AM
dropzone's Avatar
Fossilized
why not come up with your own new design?
tons of people make them, try
Old May 25, 2010 | 02:11 PM
I would definitely come up with my own design. I pride myself in not just copying whats already on the market. The original question was whether they are useful in the mountain/rocks...or if they are mainly used in the sand/long travel guys. Since I cant seem to get that answer, Im assuming they are mainly used in the sand/long travel industry. Thanks!
Kyle
Old May 25, 2010 | 02:14 PM
2DoorRunner's Avatar
I dont really see how they would help with different kinds of terrain
But a buddy of mine at work is running 4.70 t case gears and he blew up a couple motor mounts. Replaced them with solid ones. And since he drives to go wheeling he hates them because they vibrate your teeth out. He says his whole body is tingly after a long drive.
Old May 25, 2010 | 02:44 PM
Sorry for the confusion. I wasnt asking if they would be better in different terrains. I was wondering if they were a product intended more for the sand guys, because they are WOT alot more than anyone who is in the mountains rock crawling. Im just trying to get ideas for things to make. Ive picked up a couple new ideas that Ill put together over the next few months. Thanks to everyone!
Kyle
Old May 25, 2010 | 02:45 PM
BigBluePile's Avatar
I have ONE Rockstomper poly mount in my rig that I had to pull and modify a little to help reduce the vibs. You'd be pretty high to run dual poly mounts on a DD rig. The reason why I installed mine? I got tired of busting my electric fan blades due to the motor rocking FORWARD. Now it just rocks up and down. Runnin duals or banging gears offroad, rocking back/forth or racing ricers on the street a poly mount will help, a little, transfer more torque down thru drivelines.
Like was mentioned, a chain would work or even a bolt thru the mount with help...
Old May 25, 2010 | 02:59 PM
Thanks for the input. So what Im gathering, is it probably wouldnt be a product that a bunch of guys would want to buy...unless they had an offroad only rig. Thanks again!
Old May 25, 2010 | 04:02 PM
For dual poly mounts yes. A single poly mount is fine in a DD
Old May 26, 2010 | 02:45 PM
Thanks. Much appreciated.
AustinTaco
Aug 22, 2022 10:45 AM
voiddweller
19
May 2, 2016 09:10 PM
Mr.Black
Jun 21, 2015 10:17 AM
XtremeOff-Road
16
Jun 27, 2002 07:32 PM
sassy4runnerchic
18
Jun 6, 2002 02:21 PM
