Regearing electric locker
Old Oct 16, 2005 | 10:13 AM
EUROJulian's Avatar
Regearing Tacoma electric locker, pinion problem.
Hi there! I have toyota electric locker I would like to regear to 4.88 ratio. I got V6 Yukon gear, unfortunately companion flange spline on the pinion shaft from Yukon is smaller than one from e-locker.
Should I got companion flange and nut from open diff V6 or there is more involved in it? Thanx.
Old Oct 17, 2005 | 04:49 AM
ZUK's Avatar
ZUK
I don't have any experience on the late model 3rd you emailed me about.....10 or 12 bolts on the 3rd member holding the ring gear on?
Old Oct 17, 2005 | 07:49 AM
EUROJulian's Avatar
Hi ZUK.
There is a pleasure of modifying stuff. Just hate to be pioneer ...
I got my locker out of TRD Tacoma, according to knowledge circulating alround enthusiasts, it should be the same as 4runner one.
To test that claim, I ordered OEM pinion bearings and diff gasket from 2000 4Runner. Parts were the same as the one in Tacoma locker and gasket fit the Tacoma locker.
I think Toyota modify the pinion in late models for greater strenght. Spline diameter is 29.5mm, thread diameter 22mm spline count 29. Contrary to what I belive is V6 gears from Yukon (part number YG TV6-488) having 27.5mm spline, 20mm thread and 27 spline count.
One thing I can think off is to order companion flange and nut from 4Runner. Hope it fits OK otherwise I be a proud owner of quite expensive pile of parts :pat:
Old Oct 17, 2005 | 08:44 AM
sschaefer3's Avatar
I have had Yukon 5.29's in my E-Locker since 2002. There is an E-locker master install kit and a standard 8" V6 install kit.
Make sure you have the e-locker install kit. Your not a pioneer by any means, hundreds of us have re-geared e-lockers.
Old Oct 17, 2005 | 10:35 AM
EUROJulian's Avatar
I know I`m language challenged and my English is not that good so your confusion sschafer is easly explained. There is particular problem on hand with my late model Tacoma TRD E-Locker sschafer, never before reported. Not even gearhead like ZUK is aware of it. I need solution to that spline problem.
You say there is a E-Locker master instal kit that includes companion shaft and nut? Is that right?
Old Oct 17, 2005 | 10:42 AM
sschaefer3's Avatar
What year truck is this e-locker out of?
Old Oct 17, 2005 | 11:07 AM
EUROJulian's Avatar
I would say 2002 or later. Do not know exactly...
Old Oct 17, 2005 | 11:14 AM
sschaefer3's Avatar
It should be the same as all the ones we have. I don't know, but many of us have re-geared the e-lockers.
There is a seperate master install kit for the e-locker, but they do use the same R&P as the standard V6 8" diff.
Old Oct 17, 2005 | 11:52 AM
EUROJulian's Avatar
It should be the same as all the ones we have. I don't know....
I know, I know.... It should but ain`t....
Hate to pioneer...
Old Oct 17, 2005 | 12:21 PM
EUROJulian's Avatar
Just got off the phone with Marlincrawler tech. (Damn you people keep that phone line busy all the time, couldn`t go trught ...)
Gent was so kind and confirmed that replacing companion flange should take care of the issiue....
I need to order 4Runner flange tommorow. I will post outcome.
Thank you all for the interest in this thread.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
Project90
Sep 24, 2015 11:40 PM
toyotasaurus
Sep 24, 2015 03:30 PM
sonorn67
Sep 19, 2015 05:39 PM
zz_denis
Sep 6, 2015 03:43 PM
