Regearing electric locker
Regearing Tacoma electric locker, pinion problem.
Hi there! I have toyota electric locker I would like to regear to 4.88 ratio. I got V6 Yukon gear, unfortunately companion flange spline on the pinion shaft from Yukon is smaller than one from e-locker.
Should I got companion flange and nut from open diff V6 or there is more involved in it?
Thanx.
Thanx.
Hi ZUK.
There is a pleasure of modifying stuff. Just hate to be pioneer
I got my locker out of TRD Tacoma, according to knowledge circulating alround enthusiasts, it should be the same as 4runner one.
To test that claim, I ordered OEM pinion bearings and diff gasket from 2000 4Runner. Parts were the same as the one in Tacoma locker and gasket fit the Tacoma locker.
I think Toyota modify the pinion in late models for greater strenght. Spline diameter is 29.5mm, thread diameter 22mm spline count 29. Contrary to what I belive is V6 gears from Yukon (part number YG TV6-488) having 27.5mm spline, 20mm thread and 27 spline count.
One thing I can think off is to order companion flange and nut from 4Runner. Hope it fits OK otherwise I be a proud owner of quite expensive pile of parts :pat:
... I got my locker out of TRD Tacoma, according to knowledge circulating alround enthusiasts, it should be the same as 4runner one.
I have had Yukon 5.29's in my E-Locker since 2002. There is an E-locker master install kit and a standard 8" V6 install kit.
Make sure you have the e-locker install kit. Your not a pioneer by any means, hundreds of us have re-geared e-lockers.
I know I`m language challenged and my English is not that good so your confusion sschafer is easly explained. There is particular problem on hand with my late model Tacoma TRD E-Locker sschafer, never before reported. Not even gearhead like ZUK is aware of it. I need solution to that spline problem.
You say there is a E-Locker master instal kit that includes companion shaft and nut? Is that right?
It should be the same as all the ones we have. I don't know, but many of us have re-geared the e-lockers.
There is a seperate master install kit for the e-locker, but they do use the same R&P as the standard V6 8" diff.
It should be the same as all the ones we have. I don't know....
I know, I know.... It should but ain`t....
Hate to pioneer...
Just got off the phone with Marlincrawler tech. (Damn you people keep that phone line busy all the time, couldn`t go trught
Gent was so kind and confirmed that replacing companion flange should take care of the issiue....
I need to order 4Runner flange tommorow. I will post outcome.
Thank you all for the interest in this thread.
...)Gent was so kind and confirmed that replacing companion flange should take care of the issiue....
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
Sep 24, 2015 03:30 PM
sonorn67
Sep 19, 2015 05:39 PM
zz_denis
Sep 6, 2015 03:43 PM
