Marlin's twin stick, how could I have missed this?
Old Dec 18, 2003 | 10:15 PM
scott.475's Avatar
I know, I know, you have to have twin sticks with dual t-case. BUT, what if you aren't running duals? Check this out, from Marlin's site..."What you might not know is that these patterns are controlled by two seperate shift rails that operate both 2WD/4WD and High/Neutral/Low respectfully. With Marlin Crawler's new Twin Stick Shifter, we can now separate these patterns and offer the user a 2WD-Low range selection. Since both rails are now independent of each other, they can be moved in any pattern desired. 2WD-High/Netural/Low and 4WD-High/Netural/Low. When used with a Marlin Crawler dual transfercase, you now have the option of 2WD-Double Low range. Marlin Crawler's new Twin Stick Shifter does just this and is very simple and innovative at the same time."
I have passed over this so many times, just thinking it was intended for dual cases. For some reason I actually looked at them tonight. I think the option of 2-lo is pretty cool.
Old Dec 19, 2003 | 06:27 AM
Shane's Avatar
Re: Marlin's twin stick, how could I have missed this?
No, you can but you don't have to...
You can indeed put it on a single case to get 2-low, I think it's actually more usefull when used in that scenario since with duals you get a 2-low mode already when you put the front case in low range. Adding a twin just gives you 2-low on your rear case which then allows 2-low-low as well which in the NW is pretty much useless. I bought one, never installed it, and sold it a while ago.
Old Dec 19, 2003 | 07:01 AM
Napoleon047's Avatar
twinsticks are really only useful if you have a front locker.
Old Dec 20, 2003 | 09:42 AM
toy283's Avatar
The picture kinda sux but you also need a twin stick shifter to make a "triple-stick" like I did. Best benefit of that is it keeps all the shifters in the stock hole:
Old Dec 20, 2003 | 11:50 AM
Shane's Avatar
You mean like this?
Old Dec 20, 2003 | 02:37 PM
scott.475's Avatar
Originally posted by Shane
You mean like this?
Man, that is cool. I can't wait to learn to weld, bend and fab, but alas, priorities conspire to work against me!
Old Dec 20, 2003 | 07:47 PM
4Crawler's Avatar
I'll be making a triple stick shifter for my dual cases. It'll add on to my short throw shift kit and move all the shift lever onto the forward case. My main goal is to free up the space over the rear case for a useable center console.
Old Dec 26, 2003 | 06:31 AM
BajaTaco's Avatar
Here is one from Front-Range Offroad...
http://www.frontrangeoffroadfab.com/twinstick.htm
Fits Tacoma and 3.0 manuals, not sure about 4runner.
Old Dec 26, 2003 | 09:23 AM
Cebby's Avatar
Will you be selling something like this?
Old Dec 26, 2003 | 06:26 PM
BruceTS's Avatar
I had a long talk with Marlin about installing the twin stick in the newer transfer cases. the problem is the case needs to be completely disassembled. The interlock pins can't be as easily removed like the earlier design and they also made one of the forks longer to prevent independant movement. This fork will need to be ground down, considering it's hardened and in a tight location, trying this while still together is gonna be very difficult and time consuming.
If I can get another chain driven case I may take it apart to do the mod, but I with my current set-up I really don't think it would be needed.
he's gone
7
Dec 3, 2019 07:08 AM
JHalcyonM
Mar 6, 2019 08:37 AM
81Toy4x4
Sep 7, 2015 06:17 AM
shisha1999
Aug 14, 2015 01:33 AM
priest16
15
Aug 6, 2015 07:43 AM
