Lockers
Old Oct 26, 2007 | 07:07 AM
  #41
Ringmaster's Avatar
Originally Posted by melkor
what is the benefit of a detroit locker? when they say "automatic locking" does that mean that it only turns on when your tires slip? or what? why are they different from, say, aussie lockers?
A Detroit is locked in all the time, the only time they unlock is when one wheel has enough traction to overcome the spring inside the locker itself.
Fine for the rear axle but a no-no for the front axle.
Even having a Detroit in the rear makes for some hair standing times on a snow or ice covered road.
The vehicle want's to go straight ahead because of the locker, steering is very effected by that.
Old Oct 26, 2007 | 07:14 AM
  #42
melkor's Avatar
so an aussie engages only when you gas it? if it is the exact same principle as a detroit, why are detroits so much more expensive?
Old Oct 26, 2007 | 08:10 AM
  #43
tc's Avatar
tc
A Detroit replaces the whole carrier, and is therefore MUCH stronger than an Aussie which only replaces the spider gears inside the stock carrier.
Have you read the Lockers FAQ sticky at the top of this forum?
Old Oct 26, 2007 | 11:21 AM
  #44
melkor's Avatar
from what i have read, people are very pleased with their aussies though. in what kind of situation would an aussie break or fail where a detroit wouldn't?
Old Oct 26, 2007 | 05:03 PM
  #45
BigBluePile's Avatar
If you're going to run 32's with 4.10's, I wouldn't think you could break either one. As far as Detroits breaking...hmmmm maybe somebody else can chime in with a story about that. If your going for the easiest install WITHOUT tearing the ring and pinon apart, then go with the Aussie. Just don't put it up front. Put something in the rear end first, who knows that may be good enough and you won't have to worry about the locking the front.
Old Oct 29, 2007 | 06:54 AM
  #46
xcmountain80's Avatar
I'm happy with my aussie in the front though I did install Manual hubs to do so. I've heard some crap about the tru-trac's breaking but not the full on lockers themselves.
Aaron
TheBFA
Feb 15, 2020 06:55 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
Toys4parts
Sep 26, 2015 01:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
zz_denis
Sep 6, 2015 03:43 PM
