Welding a V6 third
Old Oct 30, 2007 | 11:39 AM
WFO's Avatar
WFO
Welding a V6 third
Who here has done a Lincoln locker on a V6 third? I see that you cant just pull the third member and weld it up because you cant get to the spider gears. How much work are we talking about to get the spider gears out and get them back in once they're welded.
Thanks
Old Oct 30, 2007 | 11:43 AM
tc's Avatar
tc
I have heard that welding Toyota diffs is extremely difficult to do well.
A spool only costs what, $100?
Old Oct 30, 2007 | 11:51 AM
WFO's Avatar
WFO
On the 4cly thirds you can get to the gears easily.
Yeah a spool isnt expensive but you have to set up your gears again. Im looking for a free locker that can be done in an evening. Just curious to see if anyone on here has done it.
Old Oct 30, 2007 | 12:13 PM
Ganoid's Avatar
I have done it a few times for others. Toss it in the BBQ to pre heat it as a whole. Weld the crap out of it then let it cool SLOWLY don't put any water on it. Actually the slower you can cool it the better. Maybe put it back into the BBQ and then turn the BBQ off so they can cool down together slowly.
Be sure to put a crappy ring gear on to keep the weld spatter off the mating surface. This one was run with 38.5 swampers on an 85 4runner and I never got any calls on the welding or the 5.29's until he decided he had more gears to set up in another truck
Old Oct 30, 2007 | 12:16 PM
Ganoid's Avatar
You dont really have to "Set up your gears again" as your pinion depth will remain unchanged and thats the longest part of a gear set up. You will need to swap 2 bearings then reset you backlash and carrier bearing Pre-load. With the proper tools thats a 10 min job once the spool is mounted.
Old Oct 30, 2007 | 01:07 PM
dropzone's Avatar
Fossilized
Nice Job Sean! What is your opinion of a welded diff on the streat?
Old Oct 30, 2007 | 01:50 PM
Ganoid's Avatar
I have never run a welded diff to be honest. I do think that a full spool would be more predictable than a lunch box style locker on the street but it will wear tires faster and require more throttle when turning to keep rolling. I'm a bit of a wimp when it comes to ride quality so I run a TruTrac in the rear of my truck because I drive it every day. I have often pondered swapping it out for a full Detroit but I really haven't had any reason to justify it. The Trutrac has never let me down. Part of the success of the TT in my application is with the dual cases I can pull my E-brake 100% to force a locking effect and not kill the motor in 4.7 or 10.7 low range.
If I found a good deal on a full Detroit for my V6 carrier I would swap them out and just sell the TruTrac but I have had no such luck so far.
Old Oct 30, 2007 | 09:03 PM
tc's Avatar
tc
See the sticky at the top about welded/spooled thirds?
Old Oct 31, 2007 | 05:15 AM
WFO's Avatar
WFO
Thanks a bunch! Thats exactly what I needed to see. Looks like I might be tearing out my rear in the very near future.
ladybugRC
458
Aug 21, 2020 10:41 AM
tazman1972
11
Sep 28, 2015 10:32 PM
ktm192k
Sep 24, 2015 03:36 PM
runnermedic
13
Sep 21, 2015 05:20 PM
Hugh_Mann
Sep 16, 2015 03:59 AM
