which hole does it go in?
Old Sep 20, 2007 | 03:54 PM
chad99's Avatar
Talking which hole does it go in?
maybe its a stupid question but where does the lockright pin go in A or B....I think A (circle hole) but i have seen a pic from somewhere that someone put the pin in B (ovalish looking hole) at least it looked that way from the pic.
Old Sep 20, 2007 | 09:07 PM
deathrunner's Avatar
I could be wrong, but you have 4 pins and 4 springs, doens't one of each go into those holes?
Old Sep 20, 2007 | 09:10 PM
ozziesironmanoffroad's Avatar
IFS IS FOR LOSERS
na not really, solid axle is obviously better for certain stuff. id bet u my truck would beat yours in a jumping contest.... haha. if i knew how to do it, i would go SA though
Old Sep 20, 2007 | 09:52 PM
jungle_runner's Avatar
yeah .. it depends ...
Old Sep 20, 2007 | 09:53 PM
Originally Posted by ozziesironmanoffroad
IFS IS FOR LOSERS
SA or IFS ... all depends on what you do with your truck ... baja racing ... IFS ... rock crawling ... SA
i'm more of a ... i want to drive 50 miles per hour through the dessert and catch mad air type of guy ... although give me some knarly crawl'n terrain and i won't complain
Old Sep 20, 2007 | 09:54 PM
stormin94's Avatar
Definitely a catchy title...but if you have to ask, maybe you shouldn't be down there in the 1st place...
Old Sep 20, 2007 | 10:05 PM
4JOGGER's Avatar
Hey, there's 4 of them in that picture.
Old Sep 20, 2007 | 10:06 PM
4JOGGER's Avatar
Actually, second look tells me there are 7
Old Sep 21, 2007 | 07:38 AM
Here are some pics of an Aussie locker install, essentially the same mechanism:
Slightly different design, but 1 spring and one pin goes in each hole. Not sure of the orientation, I imagne the spring goes into the ovaled hole. Just a guess. I would contact the manufacturer to be sure. They probably have the insturction on the page.
Old Sep 21, 2007 | 08:29 AM
chad99's Avatar
haha true and i figured out that it can only go one way (or the smaller springs would fall through the holes) but there was this someone on these forms that installed one and it was always locked, they complained to lockright and took a pic of it once it was removed, and from the pic looks like the dude put the pins in the wrong hole.
Old Sep 21, 2007 | 08:35 AM
chad99's Avatar
Thanks deathrunner but this lockright doesn't have the area to slide in the springs along the outer edge, you have to put them in before the its bolted in the carrier, thanks for the help though.
Oh and the instructions are pretty vague when it comes to placing the springs in, they have a pic but its black and white and looks like it was taken back in the 70s w/ bad lighting.
Old Sep 21, 2007 | 08:51 AM
Chad99, like I said, the desigb is different, slightly. Such as the windows for installing the spring, but the basics are still there......a spring and pin in each hole.
Old Sep 21, 2007 | 09:25 AM
BLKNBLU's Avatar
Pins go in all four holes. Do you have an install manual? I'm going to refer to parts as they are listed in the manual. You will notice on each driver that 2 holes on the side are round and 2 are oval. When you orient the drivers during assembly make sure an oval is across from a round hole on each of the four places where the meet up. Then you can push the springs in to each of the four holes as each one will have an oval on one side or the other.
Something that I didn't pick up on until the 4th or 5th time I read the instructions was that the small springs slide inside the large springs. I nearly assembled mine with only half the springs. Did yours come with 4 or 8 springs? Your pic looks like only 4. I got thrown off on this by looking at the Aussie install pics too. They are good pics, but only use them as a very general reference as Deathrunner mentioned.
Old Sep 22, 2007 | 12:13 AM
stormin94's Avatar
I wasn't talking about the locker.....
Old Sep 22, 2007 | 12:41 AM
yotasavg's Avatar
that's what she said.
Old Sep 22, 2007 | 12:45 AM
stormin94's Avatar
Good to see someone understood my original post.....Look up toward the top at my first post on here. You'll understand.
Old Sep 22, 2007 | 12:47 AM
yotasavg's Avatar
lol. i saw that but i posted this as soon as i saw the title. way to go
Old Sep 24, 2007 | 09:54 AM
chad99's Avatar
haha sorry wasn't thinking dirty was just preping my self for being flamed ....oh and i installed it this past weekend.
thanks yall
Old Sep 24, 2007 | 06:19 PM
stormin94's Avatar
thanks yall
I'm not flaming you...
LittleUgly
15
Jan 2, 2020 01:30 PM
mreagen
Oct 5, 2015 04:27 PM
Brodetski
Sep 30, 2015 11:50 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Project90
Sep 24, 2015 11:40 PM
