Hi-Lift Jack Rattling
Old Apr 30, 2006 | 01:30 PM
heyben's Avatar
Hi All,
I have my Hi-Lift mounted to a Yakima Load Warrior using the Yakima Hi-Lift mount. Now there is a really annoying squeak/rattle when I go over bumps. I bought the isolator for the handle cause I thought the handle was banging against the body, but it didn't fix it. It might be the handle itself moving around where it connects to the base, but I can't be sure. Anyone else have this problem? Has anyone figured out a way to stop it?
Old Apr 30, 2006 | 01:37 PM
waskillywabbit's Avatar
It is probably the jacking mechanism itself. Just take the Hi-Lift off the rig when you aren't wheeling anyway and problem solved. You might also look into getting a Hi-Lift bag if you are going to leave it on there year round.
Old Apr 30, 2006 | 04:55 PM
Stump1883's Avatar
Yes I have that exact smae issue with mine. I also have Load Warrior, I thought I had fixed it many times over with different things, but it soon returns and usually with vengence. I thought it was a good idea to have it with me all the time, just in case I have to change a tire, with my 285s the bottle jack is almost useless, but this rattle is going to force me to just chance it.
If anyone has an idea help heyben and myself out.
Old Apr 30, 2006 | 05:57 PM
BeaterToyota's Avatar
The foot/base of my jack rattles against the main upright part of the jack (see red circle). I use a bungee cord (not pictured) to pull it tight in one direction and keep it from rattling.
Old Apr 30, 2006 | 06:47 PM
dragr1's Avatar
Bungee cords!
Old Apr 30, 2006 | 06:58 PM
Scottiac's Avatar
Yep, bungee cord from the plate to somewhere on the main shaft does wonders!
Old Apr 30, 2006 | 07:05 PM
Stump1883's Avatar
Done that, I've zip tied the base to the main body(jacking mechanisim) and still the rattle persist. Or am I missing something in the bungee idea.
I'm thinking alot of it comes from the jacking mechanisim it's self is whats making all that noise.
Old Apr 30, 2006 | 09:49 PM
heyben's Avatar
I originally thought it was the base too, but I pulled the entire base plate off and drove around...same damn rattle/squeak.
Old May 1, 2006 | 04:09 AM
Stump1883's Avatar
Old May 1, 2006 | 08:29 AM
Scottiac's Avatar
one other possibility that happened to me recently... kind of a stupid one (but I'm kind of a stupid guy sometimes)... Is the jack locked in the "goin' up" position? The release lever will rattle like a son of a gun if it isn't locked in place.
Old May 3, 2006 | 09:10 PM
RTdawgs's Avatar
My handle rattles because the latch is not tight enough, check that.
ashamsuddin
17
Jul 22, 2024 03:59 AM
gibbonsballer10
Oct 26, 2023 07:13 AM
zytra
Jan 24, 2019 03:16 PM
Corvoid
Dec 11, 2015 11:21 AM
Flightguy
Oct 2, 2015 05:34 PM
