bj spacers
Stock shocks will be too short. I used stock length Suzuki Samurai front shocks and they work perfectly.
33x10.50s should fit without any problems. I have 32x10.50 Super Swampers which measure only a hair shorter than a BFG 33x10.50.
33x12.50s will fit if you have rims with little backspacing. The problem won't be rubbing the tires on the body/fender/etc., but the inner sidewall might rub the upper control arm if you have wide tires and/or wheels with a lot of backspacing.
Originally Posted by wittekl
just wondering if i do balljoint spacers can i use my stock shocks or will they be too short. and do i need to crank my tbars to fit 33" bfg mt's. thanks kevin
There are some guys here who haven't replaced their shocks with the BJ spacers yet. I am one of them. The ride is still good but I haven't wheeled it yet to find out what it does when fully extended. I wanted the increased ride height, I wasn't too concerned with articulation.
Originally Posted by snap-on
I thought you didnt have to run longer shocks if you had stock bumpstops (non low profile)
The one thing that I have noticed in the last few days - since I have only had the lift in for a week. When I go to full drop, it is more harsh. before when the truck went to full drop it wasn't too hash because the shock was able to slow the drop before it bottomed out. Now I am riding on the top part of the shock and there isn't time for it to slow before it bottoms out, leaving me with a fairly good thud. If you are only driving on road you wouldn't notice much of a difference until you roll off a curb or something, but if you are in the bush I think it would be a more common experiance.
You can add some spacers to give your existing shocks a bit more travel:
- http://www.4x4wire.com/toyota/minutemods/ifs/
FS[MidWest]: 1.5" ball joint spacers
4x4YOTA
Aug 23, 2016 09:08 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
4runnerFireman
Sep 29, 2015 06:24 AM
FS[SouthCent]: TX - 4Crawler Ball Joint spacers
crash813
Sep 27, 2015 07:15 AM
