BJ Spacer or Rancho
Old Feb 7, 2007 | 07:31 AM
BigBen's Avatar
BJ Spacer or Rancho
Ok i know this(these) questions have been asked about 100000000000000 times before here...I have spent quite a bit of time searching this topic...but i still have some questions.
First off...I'm planning to do the BJ spacer lift and get 3" downey leafsprings...but my dad(who still owns the majority of this car...for the time being) had a friend who is a mechanic come over and look at the bj lift and told me that the bj spacers were ILLEGAL and that they extremely weaken the ifs and i would be better off getting a 3" Rancho lift. Now i've heard that for the most part that the people who do the BJ lift don't have any major issues and i haven't read anything about anyone saying they're illegal, and the people who do the bracket lifts (like rancho and superlift yatta yatta yatta) usually end up breaking things. What do ya'll recommend?
Second, if i do end up doing the BJ spacer lift how could i fix the angle and take some stress of the cv's? I've heard that some people put manual hubs on but what about when you put it in 4wd?
Alright i'm done rambling
any feedback/advice would be awesome
-ben
Old Feb 7, 2007 | 08:00 AM
all_terrain17's Avatar
I've never heard of anyone having strength problems with the BJ spacers. And I don't believe the IFS can get much weaker
Manual hubs and a differential drop will definitely help ease stress on the CV's.
EDIT: Illegal?
Old Feb 7, 2007 | 08:07 AM
BigBen's Avatar
hahaha
exactly what i said "illegal?" wtf i don't think so
Old Feb 7, 2007 | 08:24 AM
4Crawler's Avatar
If the spacers were illegal, so would be all the other types of spacer lifts, like the coil spacers, lift blocks on leaf springs, etc. No problems with weakness that I have heard about, and since you are spacing the whole ball joint down, you are not increasing the stress on the ball joint itself as you would if you made a spacer that fit on the stud end of the joint and lengthened it.
- http://www.4crawler.com/4x4/ForSale/...ntSpacer.shtml
And by keeping to the stock control arms and mounting points, you are keeping the stress on those parts about the same as stock. The 3" and 4" bracket lift kits increase stresses there.
Manual hubs can help with CVs as can a front diff drop:
- http://www.4crawler.com/4x4/ForSale/DiffDrop.shtml
Old Feb 7, 2007 | 08:36 AM
slosurfer's Avatar
If they are illegal, you can ask them why at least two different toyota dealers in Texas sell them through their parts dept (Toyota of Dallas and another one on the board here). Also, like said before, IFS can't get much weaker. If you do any real wheeling w/ IFS, you are going to break stuff. It doesn't matter if you are stock, bracket lift, locked, etc... stuff is going to break. More important, is knowing what breaks, and having spares and being smart. My rig has been wheeled in 9 different states this year and driven from Cali to Northern Minnesotta, so far the only suspension problem I have had was knocking my alignment off which will happen if you wheel IFS. Also, during the majority of this last year, the 4runner was my wife's dd w/ my 2yr. old son. If it in any way felt unsafe, they would not be driving it.
Manual hubs are a great idea no matter what. When you use 4wd, you just get out and turn the dial. Once they are locked, you can still shift in and out of 4wd just like you do now. Also, 4crawler, sells a 1in diff drop that should help with cv angles. I don't run one because it won't work w/ my sonoran steel rear IFS brace.
-ben
Also, you are in a tough spot. In the end, you got to go with what your dad says. It is not worth it right now to turn it into something major to come between you two.
Edit: I took too long! 4crawler already got it.
Old Feb 7, 2007 | 08:38 AM
BigBen's Avatar
hmm...interesting
well i called 4wheel parts and asked them how much a rancho/procomp ect lift would cost and they said 1300 WAYY OUT OF THE BUDJET lol
so it looks like i'll be going with the bj spacer lift
4crawler, i'll probably be ordering a diff drop from you guys within the next couple of hrs
thanks for the help
-ben
Old Feb 7, 2007 | 08:45 AM
4Crawler's Avatar
You can always install the front lift and see what your CV angles look like afterwards. If you think they will be a problem or if you run into issues down the road (boots wearing out or joints breaking), then install the diff drop. A lot depends on what lift you end up running, whether you have manual hubs or not and how much 4WD use there is.
Old Feb 7, 2007 | 08:51 AM
BigBen's Avatar
Well i go offroading a couple times a month with my friends and also go hunting once everyother month so i use 4wd somewhat alot
4x4YOTA
Aug 23, 2016 09:08 AM
89YodaRunner
Sep 30, 2015 02:18 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
4runnerFireman
Sep 29, 2015 06:24 AM
crash813
Sep 27, 2015 07:15 AM
