1st gen front lift??
Old Apr 15, 2004 | 08:20 PM
jscarrozzo's Avatar
I am planning on doing the downey 3" spring lift in the rear for my 86 4runner, and think that an inch or 2 in the front will even it out, because the rear sags a little now..
What should I go with in the front?
What else should i replace when doing this job?(Brake Lines?)
What you recommend for new shocks?? I am doing all four shocks..
I am on somewhat of a tight budget.
I am new to lifting trucks, and need some help.
Old Apr 15, 2004 | 10:34 PM
Wolfen's Avatar
if you have a torsion bar front(t-bar) suspension.
just torque her up a bit you might get an inch or so out of it and go with smaller bump stops on the top side to maintain some bound that about it .
I did a similar sus mod to mine 3"rear with about an 1 1/2 " torque up in front and as stated smaller bump stops.
good luck
Daniel
Old Apr 15, 2004 | 10:53 PM
superjoe83's Avatar
if you were planning on cranking your stock bars, don't expect them to hold the height very long if you take it off road a lot, you will over-twist them and they will lose there resiliency to spring back, for shocks, because you are on a tight budget, go with the cheapest procomps, i got mine for $30 each
Old Apr 16, 2004 | 05:34 AM
jscarrozzo's Avatar
Can you explain how to do this mod to the front? Also, are there any other solutions to raising the front. I do go offroading about once every week or 2.
Where is the best place to find the procomp's?? Thanks for the help.
Old Apr 16, 2004 | 06:26 AM
Runner-Man's Avatar
There are two large bolts underneath the truck where the torsion bars mount, near the transfer case crossmember. You tighten these bolts to pre-load the torsion bars and raise the truck. It's a good idea to measure between your front fender wells and your tires before you start and after you finish to see how much lift you dialed in. The adjusters may also have lock nuts on top of the bolts that you have to loosen first. Note that this modification will also stiffen your ride, and decrease the front end flex. You will not need new shocks or extended brake lines, since you aren't affecting the suspension travel. Be sure to have an alignment done afterward.
Another option is to purchase some ball joint spacers from Elripster (around $100). You will get about 1 1/2" of lift without affecting ride stiffness and front end flex.
Old Apr 16, 2004 | 05:33 PM
Wolfen's Avatar
Thanks for writting that up Runnerman probably would have taken me 3 hours,I'm not very good w/keyboards gota a link for those spacers I'm interested!!
my offroading frequency is about the same as yours JS and my trucks been set up like this for about a year and a half and I haven't lost any tension from the bars.
Due to availability and pricing out here I went with rancho rs 5000 up front and 7000 out back. I had the tranny out awhile back and had removed the f sway bar for accessability when I went back in I left it off as well.
you may gain a bit more flex but not any great amount but still better than none,just a suggestion
And don't forget the smaller bump stops they help with travel when you torque up.
Daniel
Old Apr 18, 2004 | 07:10 AM
4Crawler's Avatar
How To Adjust Torsion Bars on IFS Toyota Trucks
Old Apr 18, 2004 | 07:29 AM
jscarrozzo's Avatar
Great link, thanks. If i do the 3" lift in the back, should i get new brake lines(SS)?? Anything else i should replace while i am doing the job?
Thanks for all the help.
Old Apr 18, 2004 | 02:11 PM
4Crawler's Avatar
Probably need longer shocks if your old ones limit droop. Brake line may be OK, but it can be replaced if needed. Adjust the LSPV (load sensing proportioning valve) for the increased ride height.
Old Apr 18, 2004 | 04:24 PM
I have a 1st gen with a 302 5.0 ford motor.
Are there any differences in suggestions for my particular set up?
I'm actually planing on getting the bilstien 5150's for the front, but have not decicded on what to do for the back, i currently have a blown set of bilstien resivuors.
Old Apr 18, 2004 | 05:07 PM
cabbage's Avatar
You should join us on the group buy for ball joint spacers here might still need to crank the t-bars a little, but it wont be as stiff.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
coryc85
Jul 6, 2015 04:07 AM
