99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
94 T100 5spd tranny
Old Mar 31, 2005 | 06:22 AM
Barney's Avatar
94 T100 5spd tranny
Hi, I'm new here. I have a 94 T100 4x4 with a manual tranny and 190,000 miles. I love my truck and have done a ton of work on it, nothing fancy just replacing worn out stuff. The body is in pretty good shape and the motor is in great shape. But..............
Lately I have had 2 tranny problems that I believe are not related:
(1) If the truck has been driven a while and I try to go into Reverse the gears grind. Interestingly, when the truck is not warmed up I do not have this problem. Synchronizer?
(2) It is getting hard to shift into 1st, not other gears, just first. There is no grinding or anything its just like the gear is not there. Shift fork?
The fluid level and quality are fine.
Any one ever rebuilt one of these transmissions? How hard is it? How much would a pro job cost (roughly)?
thank you.
Old Mar 31, 2005 | 07:02 AM
Honger's Avatar
Problem #2 sounds like it could be a symptom of clutch pedal bracket failure... something very common to T100's. Basically the bracket that holds your clutch pedal cracks and eventually breaks. While cracked the bracket makes it very hard for the clutch pedal to function. So take a peak under your dash at the clutch pedal bracket... see if its cracked. Hopefully a manual-tranny T100 guy will chime in with more info.
Old Apr 4, 2005 | 06:18 AM
Barney's Avatar
Thanks for the info, my bracket is ok. I am now thinking all I need is a new clutch and to have my flywheel resurfaced.
ladybugRC
458
Aug 21, 2020 10:41 AM
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
Davebarbier
Nov 3, 2015 03:28 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
