99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
02 Toyota Sequoia DBW Throttle Issue
Old Sep 11, 2014 | 06:57 AM
newgen's Avatar
Hey guys,
I recently replaced the starter in my 02 toyota sequoia. Afterward the drive by wire doesn't seem to be working. Also the vehicle stability control lights are on. I push the throttle approx 90% of the way down and finally the cable drawn portion takes over. I've verified both plugs are plugged in for the DBW motor. It did throw a check engine light. The code was for a tps circuit B I believe.
Things i've done since then:
Cleaned the throttle body (which I may do again)
Checked the fuse for the stability control and dbw circuit.
My first instinct is to go buy a new tps sensor. It costs $400.00 for a new oen. I'm trying not to throw money at the car without first confirming what is wrong.
One other thing. When I put the starter back in I put both 14mm bolts back in. I left the 12mm harness bolt out. The harness seemed to be holding itself didn't think it was needed. This isn't a grounding point is it?
Any ideas would be greatly appreciated! I love this SUV and desperately need to get it running correctly.
Thanks
Matt
Old Sep 11, 2014 | 07:02 AM
JasonYota's Avatar
Those may be grounding points. If this happened right after you replaced the starter and left them out, I'd start there.
Also if your engine is DBW there shouldn't be any other cables attached to the TB.
You can test your TPS with a multimeter.
Old Sep 11, 2014 | 07:05 AM
newgen's Avatar
Thanks Jason!
There is a throttle cable but from i'm told its for limp in mode. It only opens up once the pedal has been pressed down id say 75% of the way. I guess its a fail safe for when the DBW system fails.
I will give that bolt a go tonight see if I can get it back in without removing the intake again.
What should the TPS measure out to with a meter?
Thanks
Matt
Old Sep 11, 2014 | 07:19 AM
JasonYota's Avatar
You check resistance across the terminals. Which ones? Not sure. The resistance should make a smooth transition while the throttle plate is opening and closing
Old Sep 11, 2014 | 07:36 AM
newgen's Avatar
Awesome thanks jason.
Old Sep 11, 2014 | 09:13 AM
vital22re's Avatar
totally a bro
go to techinfo.toyota.com pay for a 2 day use. Then you can select your rig and look up the codes. This is what dealers use for repairs.
Old Sep 11, 2014 | 09:25 AM
newgen's Avatar
Thanks! I'll give that a roll as well!
Old Sep 11, 2014 | 09:31 AM
vital22re's Avatar
totally a bro
There is a tab labeled RM (repair manual) thats where i would search. You could also check the EWD tab for wiring diagrams. I would think the DBW system would be under the engine control diagram.
JF9243176
Oct 8, 2017 04:21 AM
94 Newbie
Jul 6, 2015 04:23 AM
JF9243176
Jun 24, 2015 04:53 AM
Mohamed
Apr 17, 2003 10:41 AM
general sherman
33
Aug 2, 2002 05:40 AM
