ARB dual compressors
Old Nov 14, 2012 | 09:21 AM
justdifferentials's Avatar
ARB Air Locker
Twin Onboard Air Compressor
CONTACT info@Justdifferentials.com
CKMTA12
This compact vehicle mounted compressor has been designed to do everything! Activate your ARB Air Locking Differentials, air up a 35" tire in less than a minute and run air tools. This 100% duty cycle, 6.16 cfm compressor is built to support all of your compressed air needs.
Voltage: 12 Volts
Current Draw No Load: 28 Amps
Current Draw Under Load: 50 Amps
Air Flow No Load: 6.16 CFM
Air Flow Under Load: 4.65 CFM
Weight: 20 Lbs
Duty Cycle: 100%
Size: 4.0" Height, 7.5" Length, 10.8" Width
Features:
Available in 12V (CKMTA12) or 24V (CKMTA24) models.
Constructed primarily of light weight, high strength, engineering grade materials, including military and aerospace standard components.
Pressure switch controlled air manifold system regulates pressure between 9.3Bar [135PSI] and 10.3Bar [150PSI] suited to air tools and all ARB Air Locker equipped vehicles.
Highest air flow rate of any 12V compressor of its size on the market at 174LPM [6.16CFM].
High efficiency design consumes only 56 Amps at maximum air flow.
100% DUTY CYCLE!!!!!
Old Nov 30, 2012 | 09:43 AM
Bringing this one back up, these compressors are perfect to air your tires back up for the snow wheeling season!
Old Dec 18, 2012 | 04:30 PM
In addition to the compressors we also carry the ARB accessories including the hoses and attachments to fill tires:
Find them here.
As well as the rapid deflator style gauge that removes valve cores:
Find them here.
If you are looking for any other ARB product that you don't see on our website give us a call at 866 349 6801, or email us at info@justdifferentials.com.
Old Jan 9, 2013 | 07:21 AM
We have all the ARB gear in stock to repair and inflate flat tires! Don't get stuck stranded out on the trail or the road.
Old Feb 1, 2013 | 10:02 AM
Bringing this one back up!
Old Feb 17, 2013 | 11:31 AM
Bringing this one back up.
Old Mar 5, 2013 | 08:15 AM
All quotes sent back out!
Old Apr 17, 2013 | 10:06 AM
Bringing this one back up, here is a picture of the compressor for reference
Old Jun 14, 2013 | 05:10 PM
Bumping this one back up!
Old Jul 14, 2013 | 07:04 PM
Bringing this back up!
Old Aug 19, 2013 | 02:41 PM
Bumping this thread back up to the top!
Old Oct 3, 2013 | 08:55 AM
We have a huge inventory of ARB Air Lockers to go along with these compressors!
Give us a call to find the locker for your application!
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
Badlander
Oct 10, 2015 08:05 PM
Toys4parts
Sep 26, 2015 01:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
