Don't think Eliminator, think for yourself!
Old Aug 11, 2011 | 09:21 AM
Gravel Maker's Avatar
FormerVendor
Arrow Don't think Eliminator, think for yourself!
We have here everything to create a 3 link suspension, front or rear, and not low end stuff just to be cheap either! The kit is wrapped around 6 of our 1.25" Heat & Cryo Treated Chromoly Heims with Stainless High Misalignment, Zink Plated Jam nuts, and 1.5" Tube ID Weld Bungs and another set of the same in 7/8" for the Panhard. We add our Chassis Link Brackets, a 10 degree Adjustable Axle Link Tower, a 10 degree Adjustable Frame bracket for the 3rd link, the Axle Lower Link brackets. We finish the Kit off with the Panhard setup, an Axle Offset panhard Bracket & the Frame panhard (Inside or Outside).
We do not include the tubing because you will save alot of money buying your tube locally when you add the shipping cost of the tube, 2" x .25" wall DOM weighs over 4.5lbs a foot! If you need to change anything give us a call and we can mix & match til its right for you! We do have DOM as an option but always price it locally first...
These are $573 and $23 to ship, sound fair to you?
Old Aug 14, 2011 | 02:34 PM
FormerVendor
Thanks for trying us, 2 of these ordered with the TTECH discount code this weekend!
Old Aug 15, 2011 | 09:47 PM
FormerVendor
Keep them coming!
Old Aug 19, 2011 | 10:36 AM
FormerVendor
This is not for followers This is for those of you that think for themselves!
Old Aug 23, 2011 | 08:21 AM
FormerVendor
The right way, your way
Old Aug 23, 2011 | 10:06 AM
89silverpu's Avatar
Out of curiosity, is there a write up/instruction manual that goes with this kit? Or is it a you figure it out here are the parts kind of thing?
Old Aug 23, 2011 | 02:37 PM
FormerVendor
This kit is not a "you figure it out" kind of thing. This is a kit for fabricators, the pieces are obvious in how they are used and can be used in many different configurations.
These kits are used by fabricators on ANY chassis so instructions would be different for every application they are used for AND there are many schools of thought of how it should be done. This kit can be used in nearly any way and we will gladly customize it for anyone.
These forums can show you the way but this kit is not for the type of guy used to having his hand held and simply bolting parts on, these are for the person that has their own ideas of how a rig can work best.
Old Sep 28, 2011 | 09:57 AM
FormerVendor
Think for yourself and do it right the first time
Old Jun 8, 2012 | 09:20 AM
FormerVendor
the best selection around and always in stock
XtraCab
Apr 12, 2020 05:25 AM
Shoua
13
May 22, 2016 05:19 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
