The Ruffstuff NOT Universal 4 Link Kit!
Old Aug 8, 2011 | 02:14 PM
Gravel Maker's Avatar
FormerVendor
Arrow The Ruffstuff NOT Universal 4 Link Kit!
First off I should explain my thoughts so this dosen't sound too strange to you guys.
A few years ago I started seeing brackets that completely disregarded all the rules about Link Suspensinons as we knew them to be. The changes that have come to be accepted as the way to do it no longer care about seperation, not vertical or linear. Did those rules change overnight? No, they didn't. What changed was a few companies saw a way to make things easier, for them and the many people that bought into the idea. Now every company making anything for link suspensions has these. Why don't we?
We do not make a combination upper/lower link bracket with 4" (or less) of vertical seperation and no inches of linear seperation. I simply do not agree with it. It certainly makes installations easier but it also limits you to only what you can do using that type of bracket.
Our Link Brackets are not holding you to any pre-determined limits. Our Link Brackets ALLOW you to make your rig work as well as you can design it. Not limiting you in any way.
I know I am going to get some flack for this but I believe everyone is entitled to an opinion and this is mine. Anyway here they are, our new 4 Link Kits!
For Framed Rigs
This is it, everything in one package for a great price, and not low end stuff just to be cheap either! The kit is wrapped around 8 of our 1.25" Heat & Cryo Treated 78,000lb+ RSL Chromoly Heims with Stainless High Misalignment, Zink Plated Jam nuts, and 1.5" Tube ID Weld Bungs. Not a cartridge type joint in sight.
The Upper Frame brackets are our 25 degree 5 way Adjustable link brackets. The Lower Frame brackets are our venerable Chassis Link brackets, time tested and proven for optimum performance.
For the axle end we have our Axle Mount Link brackets and our New Truss that we have refined for additional strength while shedding uneeded pounds. On the Truss we keep it simple with 4 of our 3/8" thick Flat Bottomed Link Tabs.
For Tube Chassis Rigs
Everything on the axle is the same as the other but the tube side is different.
The Upper Chassis brackets are our 10-35 Degree 5 Way Adjustable Tube Mount Link brackets. The Lower Chassis brackets are 10-35 Degree 3 way Adjustable Tube Mount Link brackets for optimum performance.
The only choice you need to make is if the Truss needs to span a Large third member (D60, D70, 14 Bolt, Sterling, Eaton, Dodge 9.75, etc...) or a Medium sized third member (Ford 8.8, D44, Ford 9", Toyota, etc...). If you want to make more changes give us a call and we can see what we can do!
These are on Special @ $722.50 for the framed and $663 for the tubed as you see them, about 15% less Than normal prices...
http://www.ruffstuffspecialties.com/catalog/34LINK.html
Old Aug 11, 2011 | 08:07 AM
FormerVendor
If you are thinking about travel links give you at least 20% better movement that 63" Chevies. Not that 63's aren't a bad choice but links are better!
Old Aug 11, 2011 | 08:15 AM
blake.nemitz's Avatar
wish i would have saw this before i bought my tg leaves
Old Aug 11, 2011 | 09:20 AM
FormerVendor
Return them
Old Aug 15, 2011 | 09:52 PM
FormerVendor
These are easy for anyone that takes a few minutes and thinks it out, OR you could use a cookie cutter and only have a rig just as good as most. I prefer to have better for less money myself
Old Aug 20, 2011 | 07:47 PM
FormerVendor
Drowning in rabbit stew
Old Aug 25, 2011 | 09:36 AM
FormerVendor
Linking it up is actually much easier than people believe, give us a call and we can walk you through it
Old Aug 27, 2011 | 11:10 AM
FormerVendor
Linking your rig will give you at least 20% better travel!
Old Sep 27, 2011 | 01:32 PM
FormerVendor
Time to make a move!
Old Oct 14, 2011 | 08:08 AM
FormerVendor
A couple of these out to Yota Tech guys this week, thanks!
Old Oct 24, 2011 | 06:25 PM
Pritchard's Avatar
Cool...got any pic`s of it installed on a 90-95 4Runner?
Old Oct 25, 2011 | 09:39 AM
FormerVendor
I will look but I am not sure. The kit is designed to be adaptable to anything but stock gas tank users on many Toys use a 3 link in the rear...
Old Dec 1, 2011 | 03:05 PM
FormerVendor
The right way to do it, if you can think for yourself and don't need your hand held to build a simple or complicated 4 link!
Old Jan 9, 2012 | 09:20 AM
FormerVendor
We do not build specific kits for specific vehicles, we make it so you can make it better than that, with no compromise!
Old Mar 30, 2012 | 12:43 PM
FormerVendor
Time to move up in the performance league
Old Jun 13, 2012 | 12:13 PM
FormerVendor
Time to do it right !!
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
Peevedkitten
11
Aug 31, 2015 06:57 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Gravel Maker
RuffStuff
Aug 6, 2015 04:27 PM
kirkrunner
Jul 27, 2015 07:59 PM
