scuba's 1999 Tacoma Build-Up Thread
Old Dec 22, 2010 | 04:06 AM
  #341
stock as possible's Avatar
Why arent you going duals while your at it? can you not make a crawl box out of the taco tcase?
Old Dec 22, 2010 | 04:58 AM
  #342
space-junk's Avatar
IIRC, marlin is the only one who makes an adapter and they are big $... maybe thats the reason? or maybe you have to put the taco case behind the earlier case?
Old Dec 22, 2010 | 05:11 AM
  #343
Nothing he has done or wants to do is cheap.
Old Dec 22, 2010 | 09:02 AM
  #344
scuba's Avatar
The taco T case is chain driven. It can not be converted into a crawl box.
Marlin as well as inchworm both make adapters.
The adapters are the run of the mill adapters that will allow a gear driven transfer case to be bolted to my stock transmission. Like this:
http://www.marlincrawler.com/transfe...i4-drivetrains
Normally that adapter is used to bolt a crawl box behind my transmission, at which point another adapter is used to make the back of the crawl box hook up to a stock Tacoma case.
This is my adapter (on the right) that bolts a gear driven reduction box to my chain driven drivers drop case. However, since I will no longer be using a tacoma case with a drivers drop, this adapter will be sold.
But, since I already have a complete transfer case, I'm just going to adapt it to my transmission and run it with some 4.7's. I'll go duals at a later moment.
Old Dec 22, 2010 | 09:13 AM
  #345
Ah yes, I forgot about the chain/gear driven and the passenger drop/driver drop differences.
Old Dec 23, 2010 | 01:21 PM
  #346
scuba's Avatar
Parts collecting has begun!!
I've got a hit on a decently priced axle very close to me.. pretty sure I'll be picking that up soon.
I picked up an IFS steering box and IFS hubs today
The hubs will widen the axle 2" on each side.. get me closer to my Taco rear width.
Once I get the axle.. I'll rebuild it.. get a diff geared with 5.29's.. probably get marlins 25MM Pin kit with high steer arms.. FROR Taco brake mounts (with Tundra brake if they'll fit).. I'll keep stock birfs until I can save for longs at another time. Just want to get the axle under the truck.
Old Dec 24, 2010 | 12:53 PM
  #347
Bojangles's Avatar
Originally Posted by scuba
I would like to know what's pouring out from under the hood haha
Old Dec 24, 2010 | 12:55 PM
  #348
scuba's Avatar
Radiator fluid. They removed it so they could access the inner steering box plate better and so it didn't get messed up by any weld splatter. I believe.
Old Dec 24, 2010 | 02:26 PM
  #349
space-junk's Avatar
looks like its gonna be a fun project scuub... maybe when you get done ill take that trip down there... OR, ill bring my own SAS parts...
EDIT: how are you planning on gaining the full width? spacers? cuz there goes your scrub radius...
I think your referring to the radiator that they removed in that picture of the truck flexing.
really? not only did he post the answer before but if you read the damn thread on pirate you would have klnown...
how do you deal with this crap scuub? this is like the 3rd time in as many pages!
Old Dec 24, 2010 | 04:19 PM
  #350
scuba's Avatar
Should be fun for sure..
The IFS hubs bring the axle to about 58.5". With 1.5" wheel spacers on each side I'll be sitting at just about 61.5" which is .5" wider than the rear end.
I just deal. And quickly answer. I'd rather not be an ass to people commenting on my own build thread.. you on the other hand.. have at em
Old Dec 24, 2010 | 05:53 PM
  #351
GonOvr's Avatar
Well.. Plans have gotten in gear for a Solid Axle Swap. My rack and pinion is starting to leak.. I don't want to spend money on a new one. Friend of mine is buying a house and will have a 220 Welder I can use.
I'm pretty sure I'm going to go with the new Trail Gear Tacoma sas kit.
I'm going to use a stock (well somewhat) yota front axle. IFS hubs for width. FROR Tacoma brake mounts (with Tundra brakes).
Since I already have a passenger drop transfer case that I was going to use for my crawl box I think I'm just going to throw some 4.7's in it and throw it on the back of my transmission (with a marlin crawler adapter) and have a passenger side drop.
Hoping these 35" MTR's will last me until a bit after the sas when I can get some 37's.
Here's what trail gears single cab taco looks like.. They say the sas kit puts the axle center 3.5" forward of stock.. so that'll give me a little extra wheel base and plenty of firewall clearance to run 39's if I wanted.
Heres the build thread on that..
http://pirate4x4.com/forum/showthread.php?t=899272
Stay tuned.
Well im pretty tired and didn't want to read the whole thread right now but i read the first. When i got to the last page and saw the pictures of the white taco i couldn't believe that was the same truck I did back track and found your truck again and it still has made damn good progress. That white one would definitely give me something to work towards though. Keep it up man!
Old Dec 24, 2010 | 10:01 PM
  #352
scuba's Avatar
Thanks man. I appreciate the kind words!
Old Dec 26, 2010 | 04:58 PM
  #353
scuba's Avatar
Got my axle today. Its in pretty decent condition. Leaky knuckles.. painted safety orange
Its either from an 84 or an 85. Its got the bottom gusset. Steering stops aren't tweaked and the bottom of the axle isn't scarred so I don't think it was ever beat up. It looks straight so all is good.
Got about 6 grand worth of parts I need to collect before I'll be anywhere close to ready. I'm thinking about taking out a signature loan... but we'll see.
Old Dec 26, 2010 | 05:00 PM
  #354
toyospearo's Avatar
NICE!!!!
Going to be sweet!
Old Dec 26, 2010 | 05:06 PM
  #355
BigBluePile's Avatar
Sweet!
Old Dec 26, 2010 | 05:07 PM
  #356
92 TOY's Avatar
awesome
Old Dec 26, 2010 | 08:53 PM
  #357
scuba's Avatar
Just got offered a set of FREE hysteer arms!
Old Dec 26, 2010 | 08:57 PM
  #358
Slap hands!!
Old Dec 26, 2010 | 09:01 PM
  #359
scuba's Avatar
Foo shoo dude!!
I'm deff excited about that.
Just need a tie rod and drag link (with ends) and that'll complete the steering setup!
Old Dec 26, 2010 | 09:02 PM
  #360
Geez dude, moving right a long with part collecting!
