jason in tn's 1997 4Runner Build-Up Thread - "the family truckster"
Old Jan 15, 2012 | 07:09 PM
  #101
jason in tn's Avatar
hmmm, not finding what I'm looking for, I'll keep looking. If I remember right the one with the snap ring still engaged was drilled and tapped, then a bolt run into it so they had something to yank it out with....
I found that one I was actually gonna try that dut couldnt center the drill bit even with a center punch the break is to jagged Im gonna give it a go again if I can figure out a way to clean up the end of the shaft some. I actually try to weld a bolt to it but that futile as well ugh. thanks again hab.
Old Jan 15, 2012 | 07:12 PM
  #102
I think drilling and tapping is the best/only option just have to figure out how to make it work in my case.
Old Jan 15, 2012 | 08:37 PM
  #103
snowshredder555's Avatar
How deep is it in? Um, let me rephrase that...
How far is the broken piece of the drive axle into the splines?
I'm thinking a self tapping screw/ bolt, a magnet to clean any loose shavings, and then a good yank.
-Ted
Old Jan 15, 2012 | 08:48 PM
  #104
-Ted
um yea LOL its probably a 2.5 inch chunk its the whole splined section of the shaft.
Old Jan 16, 2012 | 02:36 PM
  #105
baddest94's Avatar
Hey jason if what i say makes no sense just dont pay attention LOL. I had to replace the axle in my truck when i brought it wasnt broken just bad boot but i remember taken tire, locking hubs apart, and on the spindle there is two nuts with a type of locking ring that has to come off before that part of the axle will come out. Don't think it will come out the other way. Sorry if its no help to ya but thats what i remember when i replaced mine. will be replacen the passenger side on mine before to long not broken damn boots LOL
Old Jan 16, 2012 | 05:28 PM
  #106
hey baddest thanks for the input buddy. my shaft actually broke and left a small chunk in the diff.
Old Jan 16, 2012 | 05:53 PM
  #107
ITS OUT!!!!!!!! yea me LOL
went preaty smooth finally {except the smashed thumb}. I used a die grinderto smooth out the end of the shaft, I used a cone shaped stone and wrap a thin strip of duct tape around it just leaveing the tip exposed, I didnt want to nick any of the other machined parts inside there, may not have been necessary but I have made enough of a job out of this with out doing even more damage. I then drilled as close to the center of the shaft as I could, drilling was supriseing easy I figured that shaft would be super hard but really wasnt bad I dilled about an inch deep or so then tapped it with a 3/8s tap. threaded in a long bolt. I dont own or have access to a slide hammer so I loosely clamped a pair of vise grips to the bolt, tapping on the vice grips from the axle side{ this is where the smashed thumb came in} after about three solid hits it poped out. this has been a learning experiance Ive learned I really dont want to have to do it again LOL but if I do I wont be so intimidated by the whole thing I learned how to change cv shafts and thats a good thing. My thumb hurt so bad after I got it out I called it quits but all I have to do now is put things back together.
p.s. hab while I was trying to cool off some the other day I sprayed the rear hatch latch with deep creep after opening and closeing it a few times wala the rear light started working, hatch opens easier to double win.
Old Jan 16, 2012 | 05:57 PM
  #108
stockwell45's Avatar
Just catching up on your thread. I'm sorry to hear about your problems, at least you get an excuse to build a rear bumper. I've never heard of the shaft breaking like that, Maybe it will be easier and also safer to drop the diff and try to pull it out from the inside. Getting little bits of metal shavings inside the diff would not be good. Whatever you end up doing, good luck.
Old Jan 16, 2012 | 05:58 PM
  #109
Guess I posted too late, nice job!
Old Jan 16, 2012 | 06:05 PM
  #110
thanks stockwell, yea Im kinda excited to start on the bumper but I had to take care of this cv first. I tried to protect things from getting shaveing down in things hope I did a good enough job. pulling the diff out of one these is no easy job either.
Old Jan 17, 2012 | 04:14 AM
  #111
Terrys87's Avatar
Glad to see you made some progress. I am not much help in that area, but was glad to hear you got it. Maybe you wont have to deal with this again, but if you do, atleast it will be a little easier with experience under your belt. Great job.
Old Jan 17, 2012 | 08:51 AM
  #112
ChefYota4x4's Avatar
I concur, ... 'great job', Jason! Can't wait for the rest.......
Old Jan 17, 2012 | 02:36 PM
  #113
habanero's Avatar
WOOHOO!!! And now I'll know where to look next I'm looking for info on the shaft broken inside the dif.
Glad to hear about the light and happy for the update, thanks!
Old Jan 17, 2012 | 05:21 PM
  #114
^^^^I'm with her^^^^ WOOHOO! Good deal and glad it worked out...now on to that bumper.
-Ted
Old Jan 17, 2012 | 06:36 PM
  #115
baddest94's Avatar
Sorry jason i missed you talkn bout which end LOL. Glad to see you got it out minus the thumb guess my truck being old the the runner its only splined on the one end the other end has the flat plate with the 6 or so bolts that hold it on. Good job
Old Jan 17, 2012 | 08:27 PM
  #116
Thanks for the support everybody.
Hab I will be watching that light to make sure it keeps working.
Snowshreader I will be starting the bumper hopefully the next time Im home, to give you an idea of how it will look it be very similar to ADICTED OFF ROADs 3rd gen bumper.
The wife made me go to the Dr for my thumb, just baddly brused but she said no working in the shop today becouse we had to head back to work today, so its not back together yet wich is ok except now my 86 runner has to sit outside till I get back home, ugh I need a bigger shop oh well. Thanks for checking in.
Old Jan 18, 2012 | 10:04 PM
  #117
Terrys87's Avatar
Glad to hear the thumb will be well. I dont need a bigger shop myself. I just need 10 shops.lol.They are never big enough, but I do hear you on the bigger shop.
Old Jan 19, 2012 | 09:31 AM
  #118
Hey, ....where's the pics of the BOO BOO????? I took pics of my booboo! lol. JK, GLAD it's not broken, buddy! Very glad about that... But WOW, that smarts!(I know well, don't I? hahaha).
Hope my PM about the bumper stuff didn't upset ya ........ not my intent. lol. Seriously, lemme know if you got that, k?
Old Jan 19, 2012 | 12:29 PM
  #119
http://images.search.yahoo.com/image...becl&fr=mcafee
Click to the right 3 times, you'll see what we were talking about....
Old Jan 19, 2012 | 12:35 PM
  #120
http://i150.photobucket.com/albums/s...r/IMG_3460.jpg
