habanero's 1996 4Runner Build-Up Thread
Old Apr 7, 2021 | 05:53 AM
  #4141
Jomoka's Avatar
4-wheel steering is a pretty high-end feature on cars these days.
The funny(?) thing about this is how absolutely certain we were it was coming from the front suspension when listening from inside the car. *clunk*, clearly coming from the driver side footwell. No doubt about it.
But get out of the car while it's driven around in circles an :^O it's coming from the rear. Not only that, but you can see the axle wiggling back and forth what looks to be almost an inch (combined wiggle on both ends of the lower control arm, plus the small amount of bushing deflection).
Now I'm pretty sure the occasional clunk I get from my '99 (which absolutely sounds like it's coming from the passenger front suspension from inside) is probably coming from the rear. I've done the same thing, looked over the front suspension multiple times and never seen anything amiss. And yet *clunk*.
Old Apr 7, 2021 | 11:45 AM
  #4142
habanero's Avatar
Originally Posted by chuckles89
Might as well scrap the whole truck. I can take it for you down here in Tennessee. I could get you a few more bucks for it at the scrapyard
Hahahahaha....you're YEARS ahead of me in terms of your truck, like about 30 of them. If me and the '96 are not pushing daisies in that many more years I just might take you up on it.
But probably I won't.
Old Apr 7, 2021 | 01:15 PM
  #4143
space-junk's Avatar
Originally Posted by dropzone
between you and BBP i am screwed...i might as well put the 4runner on craigslist. some HS kid will buy it
Originally Posted by habanero
Whoa whoa whoa whoa back that horse right on up!
(sorry, we're back to reverse again)
Old Apr 7, 2021 | 01:18 PM
  #4144
habanero's Avatar
Transmission even minus bell housing and fluid is HEAVY. It's in the box, snug as a tranny in a, um, box.
I was able to put the trans in the box, but the box is too awkward to throw in the car so will have to wait for my SuperHubby to show up.
I'm only 30# more than it is, gonna need some helps.
Anyway, the old R150f is going back to Marlin in the next day or two.
space-junk...the like button disappeared, otherwise I'd smack that thing
Old Apr 8, 2021 | 11:00 AM
  #4145
space-junk's Avatar
hey hab, i was just thinking... if you get the mount fixed, you should replace the worn out bushings with some machined delrin bushings. thats what Dirt Designs put in the LT kit that i have. and most aftermarket companies swear by delrin simply because it doesnt require grease and doesnt break down likie rubber or poly. and do what Gevo did on the rear of his second gen with the heims and beefy arms. https://www.yotatech.com/forums/f199...5/index21.html
Old Apr 8, 2021 | 01:08 PM
  #4146
habanero's Avatar
This I didn't know, thanks for the link, I'll look into it.
Old Apr 9, 2021 | 02:19 AM
  #4147
Kitty's 4Runner's Avatar
You are all so very awesome!
One thought was to have the holes built back up and drilled to the proper size like Kitty says, but if I had that done (I need a Kitty here!), then added the washers you all mention to shore things up a bit that might just be crazy enough to work.
You had me at hello Hab !
Last January, we'd booked a trip to the States for this November, and Montana was on our Itinerary, but the damn "Covid" has stuffed all that.
I'd be thrilled to give you a hand, yes please, a couple of hours would kick the whole job in the butt.
Can I have a rain check ?
Old Apr 9, 2021 | 05:44 PM
  #4148
habanero's Avatar
I'd be honored and a half, but I hope you don't mind if I try to get this done sooner.
I've never been to Montana, hear it's beautiful. Hope you get a chance to see it at some point.
Old Apr 10, 2021 | 05:24 AM
  #4149
LoL, Stoopid Aussie, I saw "mo" in your signature and assumed Montana... not Missouri.... well I'd be happy to make a detour, but it might be a while...
Old Apr 10, 2021 | 06:30 AM
  #4150
habanero's Avatar
Not even all Americans know the abbreviations! Don't ask me a thing about Australian...areas? Cities? Not. A. Clue.
We're just a 4 day round-trip diversion not including hanging out...if you really like to drive for long hours. Missouri's got caves, streams, and beautiful tall oak trees. We also have ticks, mosquitos, and rust!
Old Apr 11, 2021 | 09:10 PM
  #4151
JBurt's Avatar
I've never seen that mount chewed out like that, but I like the washer idea. Plus it would be easy to grind off and start over if you needed to.
Old Apr 12, 2021 | 04:24 AM
  #4152
habanero's Avatar
I'm thankful for and lucky to have the people who follow and help me out with great thoughts, ideas, and suggestions. It's not a build thread any more, it's a help me keep this dang thing afloat thread.
Old Apr 12, 2021 | 11:54 AM
  #4153
JBurt's Avatar
Floating like this, right?
Old Apr 12, 2021 | 01:07 PM
  #4154
habanero's Avatar
THAT'S NOT ME! I don't swim so, vicariously, either does the 96
That pic made me think of Gangus2006 standing in the back of his mom's 4Runner holding a tow strap...in a pond...
Old May 5, 2021 | 08:59 PM
  #4155
dropzone's Avatar
Fossilized
Hey Hab- have you and mr. jomoka worked out a plan of attack for the wobbly wiggled and woggled hole yet?
curious if it’s fixed or if you are ordering a SAS kit
Old May 6, 2021 | 04:28 AM
  #4156
habanero's Avatar
STOP POINTING ME AT RABBIT HOLES!!!
I haven't come to a conclusion yet, but planning on keeping it IFS so will have to have it repaired sooner than later. I really like the washer plan that I can't do my ownself. Also looking at emkeith's lower link mount/skid as a reinforcement for the repaired holes. It looks solid, but I'd have to modify the right one to accommodate the slider mount and am a bit worried that it covers the original, here in the salt belt not being able to reach for thorough cleaning and inspection might be trouble?
Yesterday I spent some time cleaning up, greasing, clearing the drains, and waxing the sunroof contact areas. It was starting to get catchy when I wanted to lift it.
I also finally got around to using sound deadening to cover the open holes that I cut into the rear door lower pockets to accommodate the larger speakers.
And birds are still jerks.
Old May 8, 2021 | 04:00 PM
  #4157
habanero's Avatar
96 4Runner 316,xxx miles
Spent some time fixing small issues.
Loosened the p/s belt some, seemed too tight.
Realized the truck didn't recognize the hatch being open- and the door open light didn't work either. Some years back I'd pulled the hatch latch apart to repair the switch so access was super easy this go-round. I found corrosion on the door switch. Cleaned it and buttoned it back up. Problem solved.
I pulled it the rest of the way apart to clean and regrease since I had it off.
My front diff lock light in the cluster wasn't working. Bulb was missing. When did I pull the bulb? I've had the cluster out several times, maybe I was sleep-repairing during one of them.
hahahhahahhahahahhaha
Had a rattle with one of my shifters, one of the radesigns rod nuts had backed off on one side, allowing it to loosen some. Tightened it back up. I'm out of loc-tite so I'll have to fix it for reals later.
Old May 8, 2021 | 07:09 PM
  #4158
habanero's Avatar
Oh! Almost forgot. Went by a couple of junkyards today (3 3rd gen 4Runners, boo auto trans/no locker/pretty much stripped) for funs and drove up on the scale while we were there.
Without people and tools the fat old thing weighs about 4900#.
So it's got about 1000# of extra junk stuck to it?
Maybe I need to call this my unbuild thread and start chucking stuff overboard!
Oink.
Old May 8, 2021 | 07:17 PM
  #4159
dropzone's Avatar
Fossilized
4900 pounds? Another 2k and you will be just like an FJ80!
I am scared to find out what my 2nd gen weighs
diff lights would be nice!
maybe someday I will have selectablez
Old May 9, 2021 | 07:27 AM
  #4160
habanero's Avatar
I'm going to point that out when the hubby mentions FJ80 again.
I think your beastie will pass mine in weight, now I'm curious to hear what yours is, too.
