Wont turn over
Old Apr 29, 2010 | 05:01 PM
bretskie27's Avatar
Wont turn over
Hey guys.. Thanks for all the advice lately on my new toy. So here is the scoop. The water pump, thermostat, timing belt and radiator have all been replaced. I followed the 4x4 tech writeup for replacing the timing belt and the marks were lined up perfectly.
Here is the problem...Before I took off the timing belt and waterpump the truck ran even though the accessory belts, harmonic balancer and fan were off the truck. I was able to move it in and out of the garage with no problem.
I have replaced everything and now the truck will not start. It is trying to turn over and the battery is fine. The fluid levels are all fine. My question i guess is what could cause this. If the timing was not completly correct could the engine not start. It seems like it just isnt getting gas or spark.. Has anyone had this happen to them or have any ideas the plugs look fine i pulled two and they were ok. Also all the electrical plugs that i unhooked have been plugged back in and the fuses are all good.
Hope you can help
Bret
Old Apr 29, 2010 | 05:11 PM
bretskie27's Avatar
starting fluid into throtle body?
Old Apr 29, 2010 | 06:23 PM
habanero's Avatar
Originally Posted by bretskie27
If the timing was not correct could the engine not start
Yes..
Old Apr 29, 2010 | 06:33 PM
habanero's Avatar
You got everything you unplugged plugged back in, and you're sure your marks lined up and you are using the right marks?
I am assuming 3.4...
Old Apr 29, 2010 | 06:38 PM
heresjohnny's Avatar
you sure the battery is charged? since you said you moved it with the belts off meaning the alt wasn't charging the battery
Old Apr 29, 2010 | 07:15 PM
bretskie27's Avatar
Habanero: The marks Im using are the marks on the camshafts and the top of the shroud and the marks im using on the crank is the dot and other mark. They were lined up perfectly. It is a 3.4
heresjohnny: The battery is fully charged I have a jump pack and it is putting out the right readings ill check again tommorow morning ...
It wants to turn over but doesnt make it like it has no spark.
Old Apr 29, 2010 | 07:17 PM
bretskie27's Avatar
Habanero: What is the reason the engine wont turn over if the marks are not lined up properly? Just for reference also with it being anon interfearence motor is it ok to keep trying to start it like this?
Old Apr 29, 2010 | 07:27 PM
habanero's Avatar
I didn't say it wouldn't turn over, I said it's possible it wouldn't start.
Ah, some people mean start when they say turn over, I'm not one of them. Just wanna make sure we're living on the same page.
Old May 2, 2010 | 04:05 PM
bretskie27's Avatar
figured it out... forgot to plug in a cable. Im not sure what one it was but its on the driverside of the 3.4 and is goiung into a female outlet by the water pump. Thanks for the help guys
Old May 2, 2010 | 05:02 PM
habanero's Avatar
Ahhh, glad you found it and even more glad you posted up.
The only things I could remember unplugging offhand was the maf (pulled the air box for room) and the cam position sensor on the timing cover.
Old May 4, 2010 | 04:15 AM
bretskie27's Avatar
its the cam position sensor
okamikai
Apr 30, 2018 10:19 PM
Shoua
13
May 22, 2016 05:19 AM
Dakotaneu
Aug 15, 2015 07:24 AM
JHalcyonM
Aug 4, 2015 01:19 PM
Hamonacracker
Jul 17, 2015 08:33 AM
