What are good brake pads?
Old Sep 12, 2003 | 05:22 PM
INsr5runner's Avatar
Need to replace my pads, any suggestions? I hear the TRD ones suck.
Old Sep 12, 2003 | 07:07 PM
do a search if you haven't already. there's a thread that discussed this, and the consensus was to stick with toyota oem pads.....
Old Sep 12, 2003 | 07:20 PM
CLin9383's Avatar
anyone have part numbers for OEM? thanks
Old Sep 12, 2003 | 08:26 PM
jacksonpt's Avatar
Senior Member
I'm pretty happy with my Performance friction pads. TRD used to use these pads, but the contract expired, and forwhatever reason, TRD chose not to renew with Performance Friction. Despite this, I am very happy with mine. I've only had them on for about 500 miles, so they are just barely broken in, but I do see better stopping force and less brake fade. Brake fade was an issue for me with "standard" brake shop pads.
Old Sep 13, 2003 | 07:46 AM
Toyota Punk's Avatar
I bought a set of Hawk performance pads, mostly because they were said to have better performance like TRD's or Performance Friction but also to have very little dust. I haven't put them on yet so this isn't really of help to you, but I thought I'd throw it in there!
Old Sep 13, 2003 | 08:04 AM
AznSky's Avatar
Re: What are good brake pads?
Mike wait till I come back! We can replace ours together at the same time!! But yea, stick with oem pads.
Old Sep 13, 2003 | 08:25 AM
CTB's Avatar
CTB
Hey guys,
About a month ago I replaced my front rotors and pads wutg OEM parts, and after my rig has been sitting for a little while, I always get a little brake squeal when I have to make my first stop. But, it only does it that first time, and then no more squeal. I was just wondering if any of y'all have had this happen, or what it might be attributed to. Everything works perfect, but I was just curious. Thanks for the info-
CTB
Old Sep 13, 2003 | 10:01 AM
4RUNR's Avatar
Guest
Your truck is defective, total it out
guess: rotor surface rust
Old Sep 13, 2003 | 10:17 AM
romus's Avatar
Heres a link on pads
http://www.nationalfleetparts.com/3types.htm
Old Sep 13, 2003 | 07:45 PM
ravencr's Avatar
Assuming you drive a 3rd generation 4runner, I'm running the performance friction pads that can be purchased from Autozone under the part number 4364. They have a lifetime warranty, and if you want to find out why I chose them, go to Gadget's site and review his writeup on them. They have been working fine for me!
Chris
Old Sep 13, 2003 | 07:46 PM
AznSky's Avatar
Hey Chris did you install those pads yourself? And if so.........write-up??
Old Sep 13, 2003 | 07:50 PM
ravencr's Avatar
I did, the writeup goes like this:
1) Jack one side front side up
2) Remove wheel
3) Remove long pin that's located on the inside of the rotor that holds the horizontal pins in
4) Pop the horizontal pad holding pins out, pull the brake pads out, and put in the new ones.
That's all it takes! A good thing to do is bleed the brakes afterwards, and per Gadget's recommendation I use the Motive Brake Bleeder. That's all it takes!
Chris
Old Sep 14, 2003 | 06:10 AM
jacksonpt's Avatar
Senior Member
Here's a decent "write-up" I sent someone on the board last week. It was off the top of my head, but it should be pretty accurate.
clickity click click
The link goes to the PM I sent the guy... If you can't get to the page, let me know and I'll post the steps in the thread.
Old Sep 14, 2003 | 08:00 AM
95_4X4Runner's Avatar
I also installed a set of Autozone Performance Friction pads a couple weeks ago, and love them. I messed up and went with their $29 rotors, and aren't happy with them, as they were warped right out of the box. (and I torqued the rotor-to-hub bolts to spec)
I'm going to see about a refund, and get OEM ones...I've had some decent success with finding the best price online, and taking the part number and price to my local dealer, and they'll match it, so I save $ on shipping.
Old Sep 14, 2003 | 11:12 AM
AznSky's Avatar
Jackson the link no worky.
Old Sep 14, 2003 | 06:18 PM
WT's Avatar
WT
I will also toss in my vote for the Performance Frictions. I did mine months ago when I replaced my rotors ( I added crossdrilled rotors) due to warpage and I say the dust is no worst than the stock pads maybe less. Install is a snap, once you do one side to see how easy it is the other side will probably take you 15 mins to drop in the new pads.
bigjstang
Jun 2, 2025 03:56 PM
Sep 4, 2015 09:27 AM
Sandman
Jul 14, 2015 12:36 PM
andrewtexas123
Jul 14, 2015 04:29 AM
Jnkml
Jul 6, 2015 01:20 PM
