Uneven OME Rear
Old Feb 9, 2004 | 07:55 AM
Ranger's Avatar
Uneven OME Rear
With some help from a Yotatech stud (Thanks Breezy) I installed new OME shocks and spring all round. But now that the euphoria of a new lift has worn off I have noticed that the right rear suspension sits almost an inch higher. How do you correct for the uneven lift?
Old Feb 9, 2004 | 07:58 AM
TDiddy's Avatar
You probably put the rears on the wrong sides. Pull 'em out and swap sides. The taller spring goes on the drivers side.
Old Feb 9, 2004 | 08:11 AM
waskillywabbit's Avatar
Yep
You and Yotatech stud need to swap sides with the rear coils as the one that goes on the driver's side with the gas tank on my 2000 is about 3/4-1" longer. Good luck!
Old Feb 9, 2004 | 08:15 AM
TDiddy's Avatar
If you were like me, you trusted the labels on the coils themselves. They typically have a PS sticker on the taller coil.
This is because the coils are technically designed for Austrailian vehicles, where the gas tank is on the passenger side.
I took this up with ARB USA, because its stupid that they can't label the coils the correct way for stuff sold in the U.S. Too bad they have not corrected it.
ARB ended up sending me a check for $20, which was the cost of renting a garage bay and lift to swap the coils around.
Old Feb 9, 2004 | 12:13 PM
WT's Avatar
WT
I took this picture when I installed mine last year.
http://community.webshots.com/photo/...13506322yAzZGX
There probably on backwards if you went by the labels on the springs and didn't read this label on the outside of the box.
Old Feb 9, 2004 | 12:15 PM
TDiddy's Avatar
Well I'll be...maybe they did change things after all!
Old Feb 9, 2004 | 12:20 PM
BruceTS's Avatar
LOL, I never bothered to look at my springs when I installed them. I guess I got lucky My LH spring is on the passenger side
Old Feb 9, 2004 | 12:21 PM
No sticker on mine
I got my OME stuff around the first of the year 2004 and there was no such sticker on mine anywhere, so they haven't got it all straightened out yet. Perhaps on the newer shipments they've added the sticker. Good post WT!
Old Feb 9, 2004 | 02:01 PM
goldtaco9's Avatar
Don't bet on it.
I just checked two sets of rears.
The 890's I have are labeled PS & DS but the 891's are R/H & L/H and the R/H is taller.
Oops.
Mike
okamikai
Apr 30, 2018 10:19 PM
Road Bull
Oct 10, 2015 04:55 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
icentropy
Jul 14, 2015 10:23 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
