Tranny Problems.
Old Feb 14, 2004 | 08:00 AM
YotaPagota's Avatar
Tranny Problems.
I have a high pitched bearing noise in my
'99 Taco in all gears except 4th. I have been told by many shops that my input shaft bearings are going out and I need to have my tranny rebuilt SOON. Anybody know anything about this. Thanks.
Old Feb 14, 2004 | 08:18 AM
85runner's Avatar
I've heard of that...how any miles are on it?
Old Feb 14, 2004 | 11:13 AM
TechWrench's Avatar
If the problem only happens in 4th, I would suspect the main bearings between the input shaft and the main shaft. If you check the trans specs, I believe 4th gear is a 1 to 1 ratio, which would mean the input and main shafts are turning at the same speed and that bearing is not in use.
Old Feb 14, 2004 | 11:45 AM
85runner's Avatar
Well, whatever it is results in the same solution - replace the transmission eventually. Unless you rebuild transmissions - then Marlin has bearing kits for $150.
Old Feb 14, 2004 | 01:31 PM
DarylD's Avatar
There's a guy on the Pirate board selling 2 brand new Taco trannies $800obo each e-mail Straightaxletoy@hotmail.com if you decide to replace yours I would be interested in buying your noisy trans.
Old Feb 15, 2004 | 06:28 AM
YotaPagota's Avatar
Tranny Problem
It only has 68k on it but the bearing noises are still very loud especially when the temp is above 50 degrees.
Old Feb 15, 2004 | 09:19 AM
85runner's Avatar
Not to be rude, but have you made sure there's enough gear oil in it?
Old Feb 17, 2004 | 06:10 AM
YotaPagota's Avatar
Yes, that was the first thing I checked.
Old Mar 23, 2004 | 05:15 AM
DiSperlonga's Avatar
Did you ever get your tranny bearing fixed? I have the same problem. Let me know how you fixed it.
Thanks.
Old Mar 23, 2004 | 06:32 AM
YotaPagota's Avatar
Thanks.
Yes I did but it was not a bearing, it was in the gears. I had AAmco in Lakewood do the work.
ladybugRC
458
Aug 21, 2020 10:41 AM
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
Davebarbier
Nov 3, 2015 03:28 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
