Starting Rebuilt Motor for 1st Time
Old Nov 3, 2008 | 06:53 AM
Greedy's Avatar
I finally have my 5vz all back together and am dropping it back in this week as I have time after work. It is a fully remanufactured long block I got from Oregon Rebuilders.
Is there anything I need to do before starting it up for the first time? I will obviously fill with oil and coolant, double check all connections etc. I searched online and found some info about priming the oil pump (ours is mechanical though so I don't know if we need to), filling the block with distilled water, spraying some oil in the cylinders etc...
Is anything out of the ordinary required?
Thanks!
Old Nov 3, 2008 | 07:22 AM
flatland4runner's Avatar
I have done a minor pre-lube in the cylinders. Then taken it for a good drive that isn't too high in the RPM's. Then drain/ change the oil, after about 500km. visually inspect oil and check the coolant a couple times during. I have heard of the mineral water thing but never personally tried it. I also usually stop in a parking lot or rest area ( as I do my break in drive on the highway) and just look for leaks and/or signs of blow by. All this is only after letting it run a few minutes in the driveway and looking/listening for vacuum leaks,fuel leaks,blow by, coolant etc and adjusting timing as necessary....probably didn't have to mention that. But I also take it real easy on it and just enjoy the dirty looks and middle fingers from people as they cruise by.
Old Nov 3, 2008 | 07:29 AM
Greedy's Avatar
Thanks. Whats the best method for a pre-lube in the cylinders? Go through the spark plug holes and spray it in with something? Should I hand crank the motor a few times before using the starter?
Old Nov 3, 2008 | 07:32 AM
also have these bookmarked take what you will from them:
http://kitcar.automotive.com/73476/0...-in/index.html
http://www.tundrasolutions.com/forum...ak-new-engine/
https://www.yotatech.com/forums/f2/n...ne-break-8157/
Old Nov 3, 2008 | 07:48 AM
yeah I have just used a small amount of oil down the spark plug hole,then a couple hand cranks w/ the ignition disconnected to build pressure and should be good to go
Old Nov 3, 2008 | 08:46 AM
Greedy's Avatar
Sounds good. I will post up once I get it up and running. Thanks!
Old Nov 3, 2008 | 03:57 PM
97ltd4x4's Avatar
Pull the EFI fuse and crank it several times to build oil pressure,put fuse back and let her rip.
Old Nov 4, 2008 | 11:27 AM
Greedy's Avatar
I talked to a shop here and they recommend cranking it over without the plugs in untill the oil pressure builds up, put the plugs back in and start it up.
I got the motor in the truck and all bolted to the transmission last night (which was a pain in the a$$ to get lined up right). Hopefully I will have it running by the weekend.
Old Nov 4, 2008 | 01:53 PM
hector200sx's Avatar
I would like to see some pics of the motor and turbo setup
Old Nov 4, 2008 | 02:07 PM
Greedy's Avatar
Here it is before I broke the rod. I am going back to stock for now to break in the new motor and wait untill spring to re-install and re-tune for the FI.
Old Nov 4, 2008 | 02:52 PM
how much boost where you running
Old Nov 4, 2008 | 03:13 PM
Greedy's Avatar
14lbs
Old Nov 5, 2008 | 11:28 AM
sorry ask so many questions i find your setup very interesting its the only turbod 4runner i have ever seen. how did you tune it?
Old Nov 5, 2008 | 11:46 AM
Greedy's Avatar
No problem. I am using a MAPECU2 for timing, fuel enrichment, and O2 sensor adjust while in closed loop. For fuel, I am using URD's port fueler which has 6 additional injectors in a sandwich plate between the upper and lower intake plenum. Also, I am using the Innovative LC-1/XD-16 combo to monitor and tune the AFR's.
Old Nov 5, 2008 | 11:57 AM
sounds like it was a lot of work props to you for a unique and very cool setup
Defy Concealment
Oct 29, 2020 11:01 AM
voiddweller
19
May 2, 2016 09:10 PM
bigblue82
10
Jul 6, 2015 08:27 AM
Old Red 94
Jun 16, 2015 08:32 PM
