SeaFoam Not Avail. What Else to use???
what's the deal with not being able to ship via air? My buddy has daily refridgerated canisters of fish headed to Puerto Rico. I bet I could get him to stuff some in there, but you would have to make worth his while.
Originally Posted by Teamsobaco
WHat else can I use that will do the same thing as the seafoam?
Uh Yeah
Kinda figured I would use Marvel Mystery Oil for the Marvel Mystery Oil treatment however the real question is what would be the process and what hoses should be used in treating the engine with Marvel Mystery Oil to achieve similar resuits to the Seafoam treatment since there is no Seafoam available on this tiny Island in the Caribbean.
I just have Marvel oil available...how should i go about using it?
From another site:
"Just be careful when you buy it, because the MMO name is now used on many products. They ALSO make a MMO fule additive. That is NOT what I use. I put straight Marvel Mystery OIL in the gas tank. Ironic since most of the time we don't want to burn oil in our engine, yet that is what I am intentionally doing. From their website:
ADDED TO GASOLINE:
* Cleans and lubricates fuel injectors and carburetors
* Improves gasoline mileage
* Reduces and prevents varnish and gum build-up
* Extends spark plug life
* Safe for catalytic converters and oxygen sensors
ADDED TO ENGINE OIL:
* Prevents valve sticking and clatter
* Fortifies properties of engine oil, prevents breakdown caused by extreme temperatures
* Promotes easier cold weather starts
* Reduces and prevents acid and sludge formation
Here is a non-manufacture description of what happens:
Use the directions on the back for amount to put in the fuel per gallon of fuel (4 to 6 oz. per 10 gallons of fuel). MMO goes through the carburetor as a droplet, broken up like the fuel. When it enters the combustion chamber and the gasoline ignites, it is vaporized and soaks into the carbon buildup on cumbustion chamber walls, valve guides, around the valve stem, and on the spark plug. It soaks into the carbon and eventually loosens it up and it goes out the exhaust system."
Can be added to the gas as a solvent or to the oil as a lubricant but should not be simply poured in the intake as other cleaners are.
Should not be used directly in the intake...uh-oh!!!! Thanks thats exactly what I did!!!! I can smoke the tires on the 3.slow now also swapped the PCV Valve (1/2 Hour long needle nose)... I did it on the wife's Volvo too..man does that 5 cylinder get up and go....I guess I buy another bottle and dump it in the tank. I am stranded in the caribbean where there is no Seafoam so the MMO will have to do for now...
I just used Marvel Mystery Oil today on my 4cyl 97 runner. I shut off the engine, pulled the pcv hose and poured a little down it using a funnel. ( By a little, I mean 1/4 cup. Then I put the pcv hose back in and started her up. HOLY CRAP I made clouds. It was funny as hell
The clouds kept going for 5-7 mins, then I did it again. I kept the engine running at 3000rpm until all the smoke was gone. The engine is so quiet now. I poured 1/2 quart into the engine through the oil cap and will drive for another 500 miles. Then I'm gonna change the oil, clean the 02 sensors and MAF, and finally check the spark plugs.
From what I hear, MMO is a cheaper alternative to Seafoam. Seafoam is $5 for a quart at autozone, whereas MMO is only $2. Walmart carries MMO as well, and has the 32oz (2 qt) size for $3. Well worth it.
I'd recommend trying a couple cans of Mopar Combustion Chamber Cleaner, available at your local dodge dealer. I haven't used Seafoam, but back when I had my Eclipse we swore by this stuff for doing pretty much exactly the same thing as Seafoam.
~Bill
~Bill
~Bill
~Bill
If you have any car dealers at all you should be able to get some.
01, alternative, buy, chamber, cheaper, cleaner, combustion, eclipse, gt, marvel, mopar, runner, seafoam, seafoamseafoam, toyota
